My front wishbone bush went aswel last month.. not hard to fix i just bought one from morrisons and got a guy to fit it down at cannalbank all in all £40 .
i'm sure i've seen you on yer bike. do you wear a helmet?
Nice little route that mate.
What phone you got? if your using a Nokia, use Nokia Sport tracker, it is sick! I use it for most of my rides and it's cool to see all the stats.
Dark blue helmet / (weather dependant) light blue kagool, bright yellow or red t-shirt...
Ride in a big hurry everywhere....
.G.
So This is my bike....
I've had it for 9 years now and recently things have started to go wrong... so I took it to Dales for some repairs... £265 later...
Parts list...
- HG50 (11 -32) 9 Speed Cassette
- PC951 SRAM Chain
- UN54 BS 73-113mm Square Bottom Bracket
- S3 Silver Sealed Headset
- Chain rings cleaned
- Hub Service
- 1 Pack Bearings
- Cone RHS XT/LX/Deore Freehub
- 6 x Outer SP41 for 1.2mm Cables
- 2 x Inner 1.2mm Cables
- 36 x Silver Spokes
- SG351 Wheel RIM
- 1 Pack of Brass Nipples
- Labour £40
Work carried out...
- Fitted new chain and cassette
- Cleaned chainset and both mechs in parts washer
- Fitted new bottom bracket as old unit was worn with play
- Reset gears front and rear
- Fitted new inner gear cables and outer rear cable fitted
- Fitted new headset as old unit was worn out
- Serviced rear hub as the axle was badly bent
- Fitted new RHS cone and 1/4" bearings
- Rear wheel hand built
I get the rear wheel back on Thursday after it was been rebuilt, the rebuild with all new parts apart from the hub and axle is about £80 inc. labour which is about £20 less than a new wheel!
I thought cars where expensive!!Hopefully this list of parts should last about another 9 years...
.G.
just needs a sound system and some coilies mate![]()
