Oil Catch Tank..Why you need one.
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
It is just behind my nearside front wheel arch, cable tied to the subframe mounts. No real fume issues, occasionally get a whiff of oil in traffic.
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
If I have one going from the can to the tip is that ok ? Or I'd it better to vent it to the road ? What filter should I stick on the end of it
DannyC87
Mar 4, 2008
3,459
up to you. I personally didn't want any cack going back through the turbo. Mine doesn't have a filter on it.
DannyC87
Mar 4, 2008
3,459
That's the same reason I don't want it back in the TIP.
Danny, what did you block the TIP with? A bolt? Bung? Clamped it?
wait for it......
An old spark plug! lol
It is all I had to hand at the time! A 19mm bung would be the pro way to do it!
DannyC87
Mar 4, 2008
3,459
You wont get any going back through danny thats what the catch tanks for ;)
as Ape says they are not 100% efficient.. If I stick my head under the car and rev it, a fair amount of oil vapour comes out of the road pipe...
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Since i had the baffled catch tank fitted and with the return going to the tip i have had no oil in any of my pipes, also when venting to the tip you keep the pressure in the crank which you loose venting to atmosphere.
Ape
-----Hairy Hoonigan-----
What is the crank pressure used for? Oil Seals etc?
I guess you could make your own baffles for a non baffled tank as well?
DannyC87
Mar 4, 2008
3,459
It maintains suction at idle to ensure breathers are kept free. Mine puts out a nice stream of vapour at idle so breathers definitely arent clogged.
