If I have one going from the can to the tip is that ok ? Or I'd it better to vent it to the road ? What filter should I stick on the end of it
That's the same reason I don't want it back in the TIP.
Danny, what did you block the TIP with? A bolt? Bung? Clamped it?
wait for it......
An old spark plug! lol
It is all I had to hand at the time! A 19mm bung would be the pro way to do it!
up to you. I personally didn't want any cack going back through the turbo. Mine doesn't have a filter on it.
You wont get any going back through danny thats what the catch tanks for
wait for it......
as Ape says they are not 100% efficient.. If I stick my head under the car and rev it, a fair amount of oil vapour comes out of the road pipe...
Since i had the baffled catch tank fitted and with the return going to the tip i have had no oil in any of my pipes, also when venting to the tip you keep the pressure in the crank which you loose venting to atmosphere.
What is the crank pressure used for? Oil Seals etc?
I guess you could make your own baffles for a non baffled tank as well?
It would appear some crank pressure is good but to much is bad.
