Stage 2 petrol cupras are only 1.5 bar or so, so that makes sense. You big power diesel boys are crackers!
i will probably get a new one soon because i have a feeling mine is leaking ever so slightly
Map is going on this week-cant wait!
yayyyyyy!!![]()
nor can the rest of us lol!
it should not leak at 1.8 bar-definately not, this IC has been tested at 2.2 bar, and as above also at 2.4 bar. there are other tdi owners who use this and swear by it as it really is an awesome cooler. if you are using an old cooler then yes you have a chance it may leak but not if its fairly new.
i will probably get a new one soon because i have a feeling mine is leaking ever so slightly.
I blew a brand new one in under 1k miles. But then again I run a good bit more than 1.8 bar
had the front end off to look at the intercooler and it looks like it has been pierced from a stone or something along those lines
took some measurements and sent them away to get a cooler built up tested at 2.5 bar.
1st decent map is on, however i'm having trouble with my 4 bar map sensor as it throws up a fault every time i put it in, so using the standard 3 bar and because of this i am not achieving requested boost. this combined with the boost leak the power is not all there but feels amazing!!
i would like to say repaired scott but i doubt it, when im done with it you can still have itif you get it fixed great, if not then it goes in your bin not mine lol
Well done on the progress looking forward to some dyno figures.
Dont run more than 2.2 bar - i tried 2.7bar didnt last long.
Also are you measuring EMP's?
Bobby
Bobby
What didn't last long?
I've been running 2.4bar for 15 months now without too much trouble.
Killed a flywheel but that was to be expected
You running a 2260?
My turbo blew up at 2.7 bar. I ran 2.4 bar for 30k but with a ported head i've learnt you dont need that much boost as emps are too high at high rpm.
