Hello mate, tbh I dont have the time or inclination to make anymore as I had to make the on the car to keep them square.
Feel free to copy my design though its not very complex. Just need access to a welder.
Its not quite as simple and fitting the bracket and it will fit though..
You will need to remove the aircon rad, move the water rad back by 30mm, trim a fair bit of slam pannel away, it helps to modify the crash bar to allow airflow to the whole surface of the cooler (unless you already have a forge one) and also a bit of bumpet trimmage.
I also used the slam pannel supports that were cut out as brackets to support the bottom of the cooler to keep it completely rigid.
It wasnt an easy job to get it to fit.
Very do-able though and is well worth the extra effort as it is a very good cooler and not alot of money!
Sorry I cant
help though.
Just you want to make sure you connect the bracket to the bonnet hinge in someway or the pannel will flex and the bonnet wont close!
