Thats the plan mate.
I very much doubt you will see much gains if any atall on a k03.. who knows though! There not very expensive so its well worth a try, if not just remove them and sell them on.
May aswell give it a go then
I'm guessing it's not yours James?
CYLINDER 1 CYLINDER 2 CYLINDER 3 CYLINDER 4
1 2 3 1 2 3 1 2 3 1 2 3
A 82.51 82.51 82.51 82.51 82.51 82.51 82.5 82.51 82.5 82.53 82.52 82.52
B 82.51 82.51 82.51 82.51 82.51 82.51 82.5 82.51 82.5 82.52 82.51 82.52
C 82.51 82.51 82.52 82.52 82.52 82.52 82.52 82.52 82.52 82.53 82.52 82.53
you are very exact in your work very impressed , time to get that badboy running me thinks
This is gonna help me I'm sure
Coming on wel james
Love ya wooden blocks dont ya lol
You measured this @ the dome or @ the skirt James?I then measured the pistons diameters and they were all 82.4mm on the dot.
replied to your email as well.
Yeh the dome is normally slightly smaller mate , normally half way up the skirt at 90 degrees to the gudgeon / wrist pin.
edit - just seen your picture - exactly like you did it !!!!!!
Something is wrong then.At the skirt mate. The are supposedly 82.5mm pistons but I got both 82.4 on vernier calipers and a micrometer.
They were less at the dome so I took the largest diameter
find out if they are a faulty batch from the piston manufacturer.
If they are listed as 82.5mm then they should be 82.5mm not 82.4mm
I know the machine shop will only bore to the specified piston but just make sure.
