Hey people, hoping you could help. Not long since I've had my bam 225 lcr.. In the past 2 days every time I've filled up, it hesitates on starting & when it does start the revs go upto 2000rpm??? After a few min it's fine? Runs perfect. Only ever put v power in. Thanks
Iv not got a clue about engines mate I got told that.
Cylinder 1 has oil in it that's why i have the misfire.
I got told I would need it all stripped out and get new pistons rings and valves. So I thought if im doing that I would get new rods as well.
If any can help me out on this it would be a great help.
Did I remove the sump?
Hi Bill, did you happen to notice if my oil pickup pipe was ok?
Sorry Tim just saw your post, I did yes.
Believe it or not it turned out to be the manifold. Swapped it for a relentless one and the car is fine, revs all the way to the limiter without any problems, no flat spots, flashing engine lights or misfires.
