Godspeed are local to me, very good company indeed.
Danny, you need to check the timing mate, two minutes to rule out the came belt then about 30 mins to do the cam to cam timing if its that. Longest amount of time is undoing the cam caps.
Can release tension on the cam belt easy as well, m6 stud with some nuts on with a washer will take the tension off, jump it a tooth job done.
Should you need to undo the cam caps to change the timing a tooth or two?
SOrted it now James :D
Had John Pop Round earlier todo my VVT Gasket and its seems my Timing cam to cam was a roller out But i couldnt get my head round it lol..
So quick chat to Alex and he showed me what to look for :D TADAAA Engine Runs Sweet as a nut No Leaks,No Knocking,No blowing, PERFECT....We brought it up to temp and got rid of the air lock in the system then done a full first heat cycle...
Really chuffed With it...Exhaust on idle Sounds soo lush :D..7
Little Crap video of it....Was 1c outside and was cold..
http://www.youtube.com/watch?v=C9GF9Lrjgjc&list=UUC8EEuDm_x2WuMmsW_kbNYA&index=1&feature=plcp
Huge Thanks to John for doing it for me :d
It was Finally Time for me to actually Finished the little bits of to actual make this Car road worthy..I first started off with a Nice Wash With 2x Bucket rule ,Then Followed up by a Clay bar which i was Gobsmaked on how much **** Came of with the clay..
Basically 1x Clay bar kit has done One Use Of it....(yeah I know Lol) Anway wants that was done followed up by a 2x Coats of Poor Boys Black Hole Which i left to a nice Dry Haze then polished it of with Megs Wool Mit....
Then Made a start with the PoorBoys Blue Nuba Polish which i un mittly did 2x coats with Haha,and the temperture outside was getting Cold so in between coats took far longer to set FFS!!!And Finaly i was glad to add my Clear Wax coat which was Poor Boys Nattys Blue Wax...
Yes by this point my arms were Falling off...And i had Interior and Wheels to Do yet....Lol..I did think this was too big of a job todo in one day...So quick Phone call to my Mother (life Saver) she popped round with her Carpet Cleaner so then i gave it a Nice wet vac and Clean with 2001 Cleaner :D And there was MOULD everwhere In the seat belts,Linings and seat it had set it too everything so i though Great....!!!
So Showed the Mother and yes She helped me out again with the cleaner with Suger,Soap & baking soda...WORKED a Treat!!!!
Some Outside Pictures of my ****ing Hard work!!!
Some of a Clean No Mushroom growing Mould harpering Cupra R interior LOL
I also Checked all the Bulbs,Switches,Windows,Wipers,Motors,Handbrake,Brakes and everything is working But for some Reason my Indercator stalk is playin up...So gotta Sort this out before the Great MOT....
Gotta admit is scrubbed up well considering 8months outside with no cleaning and gather much Crap!!!!Put im pleased with my Efforts ( and the Mother Cleaning TIPS)
Also Little Video of the exhaust Note on Cold Idle (I Didnt rev **** out of it...Was up to 2.3Krpm Yet it sounds alot more Lol...)
http://www.youtube.com/watch?v=RaRkcNg3_Qc&feature=youtu.be
Next for me Is MOT & TAX then i can wack the Miles on then get it all setup....then i can Fit my Godspeed 323mm x 28mm Discs,Ds2500 pads,Braided Lines,RF600 Brake Fluid,Clutch and Flywheel .....Happy Days ....
Mega Chuffed on what Me & John have Built!!!!!!:handbags:
