Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
It took like 6-8min lee on idle
Big thanks as always phil...
Finally got my Vagcom working on my Mini Dell laptop and cleared the Codes in the engine Blocks and I did a Full scan Shortly After (hadnt started it) and this is what came up
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 1ML 906 032 A
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 77875
VSSZZZ1MZ3R056288 SEZ7Z0B1737303
1 Fault Found:
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 35-00 - -
Readiness: 0110 0100
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 00001
Note: Excessive Comm Errors
Address 08 -------------------------------------------------------
Controller: ö 1M0 820
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 922 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05424
Shop #: WSC 00000
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
30-10 - Open or Short to B+ - Intermittent
01176 - Key
07-10 - Signal to Low - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
No fault code found.
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: 93 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
8 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
01332 - Door Control Module: Passenger Side (J387)
01359 - Internal Central Locking Switch: Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
then once i started it after clearing the Codes on the engine block the Car felt alot better on idle and these are the ones that came back
Control Module Part Number: 1ML 906 032 A
Component and/or Version: 1.8l R4/5VT 0001
Software Coding: 10510
Work Shop Code: WSC 77875
Additional Info: VSSZZZ1MZ3R056288 SEZ7Z0B1737303
3 Faults Found:
P1579 - 35-00 - -
17695 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-00 - -
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-00 - -
The 17987 - Throttle Actuator (J338): Adaptation Not Started Is that i havent performed a TBA...
Can anyone tell me how todo it as ive forgot...Im sure its block 060...
That's the block![]()
Looks like the timing may be out mate. Double check it. Do a tb adaption too.
