What did you and your MK2 do today?
Jun 7, 2006
2,968
Norfolk, Norwich
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,363
Northumberland
Sitting at Sedox Performance at the moment to do a few diagnostic live runs to see if these flat spots I'm seeing are map-related or something else.
shnazzle
Sep 9, 2011
3,363
Northumberland
and your sure its that and not your etg's being too high?
It seemed pretty obvious in the logs. At each point where that boost was requested, the actual would fall and flatline at 2601. We markered 6 places during the run in different gears and it did the same thing. Also happened at around 3300 in 4th apparently but wasn't as obvious. It was too sudden and quickly resolved for it to be EGTs.
Worth an ask though
Daveb77
275
8
Been a while since I went to Irvine Cruise. I'm from Ayrshire originally.
Will keep an eye out for you DB, I work in Renfrew.
All I done on the Leon today was pumped up a tyre! Got a slow puncture, TPM works a treat. Will be on holiday then working overseas for a few weeks so will be giving the Leon it's annual detail when I return.
Will do bud, where a outs you work not spotted you leon as yet...
D
Pedestrian
286
Sandbach, Cheshire, North West
Guys,
Got my car lowered the other week and they messed up the wiper, and had to go back as the motor wasn't working - don't ask how. But anyway, when they put it back on (only realised this today), the wiper doesn't sit flush against the window like it should (looks like its in the mode where they're on) Anyone any clues on why this is sitting like this?
Picture of the car lowered from a horrible angle:
Magicsky
I got the need for speed
Oct 8, 2012
299
West Sussex
Guys,
Defently not right!
What was you using for lowering ie how much? Springs or coilovers which brand?
Pedestrian
286
Defently not right!
Yep think I'll have to ¬_¬ Was hoping I could tighten something up so it fits into place...
Erm AK FK Street Coilovers - cheap ones but they're fine for how many miles I do.
And it was roughtly 50mm on both when they measured, give or take a couple of mil.
cuprat
Stage 2 rs3
Mar 27, 2008
671
aberdeen
Guys,
Think you will need vag com to set basic park position thats why I just lifted scuttle panel up a bit with small rachet.
I run spax rsx adjustable coilovers in mine
-pseudonymous-
681
Guys,
Got my car lowered the other week and they messed up the wiper, and had to go back as the motor wasn't working - don't ask how. But anyway, when they put it back on (only realised this today), the wiper doesn't sit flush against the window like it should (looks like its in the mode where they're on) Anyone any clues on why this is sitting like this?]
I think you should be able to re-align the wiper as its on a splined shaft.
Just remove the plastic cap and undo the nut, then gently lift the wiper off the splined shaft. Re-fit the wiper in the correct postion, tighten the nut back up, then pop the cap back on.
Aug 6, 2009
956
cumbria
today I spent 6hours cleaning started with a wash with auto glym shampoo, then auto glym clay kit, auto glym srp and finished with auto glym hd wax. it was the 1st time I've used clay am very impressed with the results. here is a few pics
only iphone pics so not the best quality.
