Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Managed to enable the one touch mirror fold and carbon dash, attempted to enable corning fogs but for some reason I have the right hand fog in permanently whilst dipped beam is selected.. I'll try again over the weekend!
Double check that you've selected the correct option. Another member was having a simlar issue and it turned out they have selected the wrong one, but it was only a letter or two different to the correct word.
Thats me done just about everything -
Locking beep,
needle sweep,
turning fogs
fan speed in auto
red ambience lights in all modes
changed mpg to be more accurate
Thats about all I was looking to do.....would like to change the headlight wash to be less often as Dean has done, but cannot find anything about it in the software anywhere.....
Locking beep,
needle sweep,
turning fogs
fan speed in auto
@RCOPUS
When closing the virtual machine it asks if I want to save or power off.
Do I need to select save or just power off the virtual machine.
Will the license expire after 30 days and prevent me using the virtual machine? I don't understand this snapshot thing you mentioned in an earlier post?
Glad you guys managed to get your cables running, my reputation on here remains intact![]()
Its the SWRA options. Not very obvious I have to say but im sure in german it means something
http://www.stemei.de/pages/coding/seat-leon-5f/swra-aktivierungsintervall.php
Cheers chaps (inc Dean)
Will try this afternoon......just about the go for a run out in Aberdeen with the Lotus....![]()
Mind them salt encrusted roads...
The Leaving Home lights was accepted by the car but didn't work, probably because the car doesn't have a light sensor, I was hoping they would come on anyway.
Lap timer didn't work as it came up with an error when I clicked do it.
Anyone know of a coding sequence that will make the leaving home lights work for those of us without the auto lights (light sensor) fitted?
I was hoping to do this one too.
