Took a chance on this one. Has a couple of reviews saying it works ok.
http://www.obd2tool.co.uk/wholesale/vag-cable-v12-12-0-new-version.html
Did this one work ok and do you get a disc to install the software?
Takes upto a month to arrive so still waiting. Does come with a disc
Mine didn't work with the software that came with the cable, I downloaded fromHERE, worked on Vista, and Windows 7 just double check your cable version and download the correct one and don't try to update.My cable arrived today so only a week, however it does not work with windows vista so I cannot actually use it unless anyone has any ideas?
That's what mine did, I downloaded from the site I linked with the correct version and it works fineI'll give it a go thanks. My software just said failed to initialise
Copy, only cost a tenner from China so gave it a chance and it workedIs that a genuine cable or copy
I just tried the software link. it loads up but when plugged into car and go to options test it says port ok user interface not found
From the link you posted above it looks the same as mine, the software version is on a sticker on the side.I wondered if the software and drivers are for my actual cable
Too expensive for my needs. Plus the are hundreds of people who use the replicas without issueJust buy one from i.e. Gendan Automotive. They offer a good price.
Since all the software (works like a sort of dongle) is activated only by an original cable all fake ones probably will have problems.
And when you want to sell it again you always can get at least 50% of it's price back.
Can't get it to work. loads software and test recognises cable but when plugged into car says interface not found
