FR Useless reversing light
martin j.
1,996
891
Fife
I usually reverse up the drive and so the white garage door helps a bit, if in doubt the rear foglight actually helps too, trying find where I got the cree I fitted the to the mk2, it made a huge difference.
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
I installed the reversing light from here yesterday; it's much, much brighter as well as being whiter. It has made a huge difference. I've also cranked up the power via OBDEleven to 125 so it has gone from useless to street lighting.
Chiggers
41
I always reverse up the drive. If not I would be reversing out onto a road that isn't a main road but is busy enough, with cars parked opposite, restricted visibility in both directions and therefore sticking the back end out without being able to see what's coming. I also have a white garage door, plus a light by it on a PIR switch so that comes on as the car approaches so I can see pretty much everything. Once clipped the very tip of the door mirror on the garage door as I backed in but nothing other than that
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Where do you change the power setting in obdeleven? Can you share a link for details? I've got the same bulbs on order ;)
seatgraham
485
49
I did wonder if reversing in was not a better option
Stick hazards on for a bit more light?
HazeTaze
28
I also want to know =)
Chiggers
41
At the IAM course that I went on many years ago, the instructor advised that it is always best to reverse and manoeuvre with a warm engine; technology has obviously moved on since then but on cold dark mornings and evenings trying to reverse through a cloud of your own emissions can't be easy. About the only time that I don't reverse-park is in supermarket car parks so that I can access the boot for loading. If there is a section with a pedestrian walkway between the two rows though, I would always back in so that I don't have to reverse out 'blind' to cars and pedestrians
RobM
Sep 27, 2006
4,982
Southampton
I found it here: http://obdeleven.proboards.com/thread/764/coding-adaptations
Adjusting the intensity of the reverse
With this change we can adjust the light intensity reverse.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Leuchte29RFL RA64
4 - Sub - Dimmwert AB 29
5 - Change the desired value. maximum 127
6 - Select - Leuchte28RFL LC11
7 - Sub - Dimmwert AB 28
8 - Change to the desired value. maximum 127
I originally made this change with the standard bulb fitted, which seemed to make very little difference since it was so weak. With the LED and this I can see into next week it's so bright.
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
2 - Adaptation
Thanks for link
HazeTaze
28
2 - Adaptation
Awsome mod. Makes a lot in diffrence. Should be posted in vcds guide. Btw, to make it work i only had to change Leuchte29RFL RA64.
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Changed reverse and indicator bulbs just now. Easy mod with details on here. On my st the lights had to come away from side of car rather than pull towards the back. Reverse light bulb is behind cover on boot lid which slides to the side for removal. Reverse light is very bright so don't think I'll up the intensity. Bulbs were expensive but you can't put a price on safety. Pondering red 501s for footwell now ;)
hc25036
46
I'm confused (again!). Bought this one (http://www.autobulbsdirect.co.uk/382-Twenty20-Cree-LED-12V-P21W-Canbus-Bayonet-Bulb.html) which is the one recommended on page 1 and it's nothing like the bulb installed in my 2015 FR hatchback with the LED pack. The installed bulb looks more like the bulbs that used to inhabit Christmas tree lights before LEDs!
That is about a quarter of the size of the one I bought....
Can anyone identify the correct LED bulb for me (If there is one)?
The good news - anyone want the Autobulbsdirect bulb for a tenner including delivery?
Rick
hc25036
46
I'll have to get it out again - and it's just started raining! Watch this space...
