Anybody using these leds:
http://www.autobulbsdirect.co.uk/581-Twenty20-Cree-LED-12V-PY21W-Canbus-Amber-Bayonet-Bulb.html - for rear indicators
http://www.autobulbsdirect.co.uk/382-Twenty20-Cree-LED-12V-P21W-Canbus-Bayonet-Bulb.html - reverse light
I usually reverse up the drive and so the white garage door helps a bit, if in doubt the rear foglight actually helps too, trying find where I got the cree I fitted the to the mk2, it made a huge difference.
Where do you change the power setting in obdeleven? Can you share a link for details? I've got the same bulbs on orderI installed the reversing light from here yesterday; it's much, much brighter as well as being whiter. It has made a huge difference. I've also cranked up the power via OBDEleven to 125 so it has gone from useless to street lighting.
I also want to know =)
You don't want to be hitting bush at ANY time!!
Thanks for linkI found it here: http://obdeleven.proboards.com/thread/764/coding-adaptations
Adjusting the intensity of the reverse
With this change we can adjust the light intensity reverse.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Leuchte29RFL RA64
4 - Sub - Dimmwert AB 29
5 - Change the desired value. maximum 127
6 - Select - Leuchte28RFL LC11
7 - Sub - Dimmwert AB 28
8 - Change to the desired value. maximum 127
I originally made this change with the standard bulb fitted, which seemed to make very little difference since it was so weak. With the LED and this I can see into next week it's so bright.
2 - Adaptation
Beat Bush* get Trump
*jed
What , and get a lovely orange glow to my reversing light before hitting a wall that wasn't there previously?
