Hi,
I have the following unit. It intermittently looks ups / reboots.
Does anyone know if theres a update for this unit that fixes the lockup/rebooting?
Device Part Number: 5QA035858B
Hardware H41
Software 0462
Nav BD: 6P0919866R
0820
ECE1 2017/18
SHIELD 2016-44 (build 309)
I've got the MIB 2 High in my mk3 - apparently it uses a hard drive for mapping rather than SD cards. I've tried downloading the update from the SEAT site on an SD card, and putting the SD card into the slot in the glove box, and while the system knows it's there when I insert the card, it just can't update for some reason. Very confusing.
Can't be done by the user unless you have Mapcare or have the unit 'modified' as I did.
Reactions: Tell
Hi, got my FR today, no idea which stereo it has and I can't see an option for full link? Took a few pics of the info. Any help would be great.
So what is mine then? The manual just says seat media system plus/ navi system
Select the Navigation screen then Setup - scroll down to Version info this will give you some details, try to post a pic.
Press Menu, settings, scroll down to System Info, this will show device part number, Hardware and software versions. Try to post a pic.
Going by the age of your maps I would say that you don't have the option of Full Link available as it's a pre mid 2015 car. Also I think you have the MIB1 unit.
With those map dates your car was probably built late 2014.
