Is that a car piston? Looks huge!
That’s the pistons you was Telling me about, quite big initOrdered some new pistons to dayView attachment 15514
So thats going to take some special overbore on the 1.8 !!!
@Connor H this was my set up, this is to get through till winter and going to build a tubular set upSpent hours mounting this lot, nightmare![]()
Sent from my SM-G988B using Tapatalk
Feel your pain brother.....spring cleaningSome spring cleaning and engine and box rebuild![]()
Hi mate is there any chance at all you might have broken the wires unplugging the map sensor when you took it out of your old cooler to fit into the new one? The wires are really old and very brittle and can break easy. I’ve done it myself before. They looked fine first glance but looking closer I saw I’d snapped one off as it was hanging by the insulation.Still have limp mode after fitting an fmic so im thinkings down to map sensor or n75.
Going to find a good replacement map sensor fitst that hpefully isnt 70 quid.
Plus side my intake temp was 26 celsius at 3500k WOT with fmic.
Fair enough hope you find what’s going on if it is that you can buy a repair harness off eBay cheap enough. I hate stuff like this, happens to me ALL the time one mins it’s mint and then it breaks for no reason what so ever it’s just sods law mate.I won’t rule it out and I will check as I have to get in that area soon, but I have had it in and out quite a few times and never noticed anything. Got a new map sensor on the way for the time being!
Fair enough hope you find what’s going on if it is that you can buy a repair harness off eBay cheap enough. I hate stuff like this, happens to me ALL the time one mins it’s mint and then it breaks for no reason what so ever it’s just sods saw mate.
Are the factory pins still making contact tho if the plug is broken? I’d check it with a continuity meter mate make sure it’s making the connection. Worth a check.Precisely that lol. This has been going on for a few weeks now! The clip on the plug is actually broken but it stays snug on there and hasnt come close to coming off. I hope that couldn’t cause an issue?
