All the Cupra R's in the UK have Nav High
I've used Kieren for hardware retrofits before and he's based around Bridlington...
East Yorkshire Retrofit Solutions offer retrofit solutions for many vehicles. We specialise is VWAG vehicles such as Seat, Cupra, Volkswagen, Volkswagen commercial, Audi, Skoda, MAN, Porsche & Bentley. We're also able to offer solutions for Ford, Volvo, FCA, Mercedes, BMW & more!
eastyorkshireretrofits.co.uk
...but before you shell out any money for anything. Check if you can still update to the latest version for free as @paddy6789 did.
Then if you do have to shell out you have he likes of Kieren on the link above, or the link below. Both people you can drive to to be able to do this kind of stuff who come highly recommended:
Genuine OEM retrofits and
coding for VW, Audi, Skoda, SEAT and Cupra in Durham and the North East. Reversing cameras, cruise control, immobilisers, App Connect and more.
northeastvagadaptions.co.uk
I would recommend rather than doing a long download to check that you can't update the maps just do the FeC check from the ready reckoner... that's why I produced it:
Mib2 High / Seat Plus Map Update
The ability to update the maps on these units is defined by the navigation FEC. No workaround was been found except to update the FECs (Function Enabling Code). Essentially the software in the unit runs like a 60s / 70s computer program with a parameter file to control how it behaves. The FEC is a sequence of codes that enable certain functions. In this case we are interested in the navigation high FEC. Experience with the original FECs and a retrofit when the navigation stopped working, a Google of Audi FECs provided a key as to how the navigation FEC works. It is this FEC that is the navigation Mapcare code.
A decode of this code enables you to identify the limits of being able to update the maps in the unit. A ready reckoner was produced for the Seat navigation high FEC. Mapcare is not currently supported in the UK although retrofit software follows the same controls. Whether non UK based, factory or retrofit, reviewing the Mapcare FEC tells you whether you have the ability to update the maps and when this ability will runs out.
How to do it on a Seat MIB2 Plus / High unit:
1. Hold Menu button until service mode shows.
2. Press "Function enabling codes (FEC, SWaP)"
3. Press "Installed codes"
Look for the FEC starting with
073 and note down the two last characters.
Use the table to decode the last two characters:
Code Allowed - Map Update month
| 10 | |
| 11 | 2015 June |
| 12 | |
| 13 | 2015 Nov |
| 14 | |
| 15 | 2016 June |
| 16 | |
| 17 | 2016 Nov |
| 18 | |
| 19 | 2017 June |
| 1a | |
| 1b | 2017 Nov |
| 1c | |
| 1d | 2018 June |
| 1e | |
| 1f | 2018 Nov |
| 20 | |
| 21 | 2019 June |
| 22 | |
| 23 | 2019 Nov |
| 24 | |
| 25 | 2020 June |
| 26 | |
| 27 | 2020 Nov |
| 28 | |
| 29 | 2021 June |
| 2a | |
| 2b | 2021 Nov |
| 2c | |
| 2d | 2022 June |
| 2e | |
| 2f | 2022 Nov |
| 30 | |
| 31 | 2023 June |
| 32 | |
| 33 | 2023 Nov |
| 34 | |
| 35 | 2024 June |
| 36 | |
| 37 | 2024 Nov |
| 38 | |
| 39 | 2025 June |
| 3a | |
| 3b | 2025 Nov |
| 3c | |
| 3d | 2026 June |
| 3e | |
| 3f | 2026 Nov |
| 40 | |
| 41 | 2027 June |
| 42 | |
| 43 | 2027 Nov |
| 44 | |
| 45 | 2028 June |
| 46 | |
| 47 | 2028 Nov |
| 48 | |
| 49 | 2029 June |
| 4A | |
| 4B | 2029 Nov |
| 4C | |
| 4D | 2030 June |
| 4E | |
| 4F | 2030 Nov |
| 50 | |
| 51 | 2031 June |
| 52 | |
| 53 | 2031 Nov |
| 54 | |
| 55 | 2032 June |
| 56 | |
| 57 | 2032 Nov |
| 58 | |
| 59 | 2033 June |
| 5A | |
| 5B | 2033 Nov |
| 5C | |
| 5D | 2034 June |
| 5E | |
| 5F | 2034 Nov |
For example if the Mapcare code ends in 22 you can load up to and including the June 2019 release but can't go beyond. 16 covers June 2016 but not beyond. 10 doesn't include 2015 June. 3f means you can update to November 2026 etc.
Those people with Mapcare or retrofits can check up to when they can update their maps against the serial release.
Derivation is here, post 1914:
https://forums.seatcupra.net/index.php?threads/navigation-system-updates.388586/page-96#post-4894481
Subsequent to producing the "ready reckoner", in 2019 Seat released
"unlimited Mapcare" in Europe on specific models (at least Leon Cupra with navigation high) (I.e. in the Dutch market, Leon Cupra 2019 models).
The unlimited code which you need on a retrofit to fall inline with this is:
| 073000EE | DB_EU_MIB2_HIGH_SEAT_Lifetime_Mapcare |
That particular code gives you updates to the year 2074 and should be the one that retro-fitters that claim unlimited updates should aim at. The code allows Seat to continue to offer Mapcare plus specials that have "unlimited" Mapcare rather than 3 years or 1 years. VW and Skoda have dropped Mapcare so you do not see navigation FECs in their screen subsequently but on older models you may, dependent on region. All Seat navigation high FECs start with 073000 the next two characters in Hex define the limits to the update.
Then get Kieren or someone like him to give you the
073000EE - you will be good to the year 2074... probably the VAG group will have stopped supporting MIB2 by then. That retrofitter I hear good things about. Bridlington by the sea as opposed to Doncaster not by the sea. Clue.
