I work at a garage and with Vag cars more than any other we find that the best way to bleed them rear brakes is to do that
I replaced two brake pipes and both rear flex’s on the garage mk5 golf on Friday I just bleed the brakes in the normal way the pedal felt good got to work on Monday morning did a pump and squeeze on the rear brakes the pedal did not feel as good as it did on Friday but no air coming out so it was the turn back time on the rear pistons one side with just the Flexi changed no air the other side with the Flexi and and the short pipe from Flexi to caliper changed there was air in the caliper now I had nothing coming out while the piston was not all the home but when I got to the last turn to get the piston all the way back in I got lots off air coming out. I sorted that and the pedal had resistance from the first touch
I might have to drop you a message - if this is going to save me ripping everything out and putting a new master cylinder in, I might just want to go through a few steps in more detail...
Reactions: Yellow fr
Ordered some injector cleaner last night - given the MoT is in a couple of months and I'd like to get a head start.
Something's definitely up with either my shocks or bushes though - opened the back door to check for dampness and when I closed the door - lightly - the car shook. I have a feeling that isn't supposed to happen.
I've changed the hatch struts for stronger ones. The hatch now opens with a press of the fob. Bit harder to close but not bad.
I did video it but says file too large.
Looking very fresh, Bruce. One thing that irritates me with the FR though, especially on the platinum grey ones is the silver mirror caps.
To me they always seemed like someone stuck some odd colour replacements on there as the silver and grey are so similar.
Haha I didn’t even notice this. I have platinum grey and mine are colour coded!?
Yeah know what ya mean, thought about getting them sprayed same as bodywork but do like to keep it looking OEM+
That's fair enough and I get it, just my personal view anyway.
Re sealed loom hole under scuttle and done a bit to my special engine cover
Also found out why the rear window was steaming up. Loose washer connection.
One day this car will only present me with minor issues
Reactions: Rich.T
Oh also thought about going bam inlet mani when I get a fmic.
Cupra and Cupra R both have body colour, only FR & FR+ got silver.
I painted the ones on my old FR TDI.
Same. They're a really weird matt silver which even looked out of place on my silver Leon. When someone smacked my nearside and I needed to replace it, I primed, sprayed and lacquered it and it looks awesome.
Spent the day working out how the n249 works so i can simply it and refit.
Success! Mounted the reservoir at the front upside down and hooked it straight up to the n249. Managed to use vac lines to bypass the n112.Everything else plumbed in to my existing DV lines perfectly. Once i cable tidy it i dont think you'll even notice it.
Will get a better picture tomorrow.
And the verdict is in! after running the bypass all year: Im staying with it fitted. It dumps so much quicker crisper now (i even noticed my needle dropping faster on boost gauge) and feels like it picks up a bit better on throttle.
