iammooks
1,823
1,223
I’ve got the same in there but I think it’s still leaking. Carpets are still as wet
Most times I get in the car, I'm convinced that there's still water getting in because there's water coming up through the driver's heel pad, but don't forget that the sound deadening in the footwells is basically a sponge, so it's going to be sitting in there a while - especially in this weather.
Have you tried cat litter yet? I put a few scoops of Catsan* on the worst areas and it did suck up a fair bit.
*other brands of cat litter are available.
Reactions: Woody_72
Sl1ced
797
404
No we have a wet vac at work I will try if it stops raining
Reactions: iammooks
iammooks
1,823
1,223
Ah, nice. That'll do it. I've been wanting to get a wet vac on the whole car to be honest - if you get a chance it'd be great to hear how you get on.
Connor H
1,052
518
Essex
I found a wet spot in my boot the other day on the passenger side, there was water running along the edge.
When i got my car i actually found a puddle of water by the rear light, ive got a couple of reasons to strip the entire interior but i reaaally dont want to.
Reactions: iammooks
iammooks
1,823
1,223
I've been getting water in my boot recently too. I've been keeping some big bottles and all of my cleaning stuff in there recently, so it's possible they've just attracted moisture and condensation and that's where it's come from, but when I changed the boot interior light for an LED one a while back, I noticed that the fitting had some corrosion around it, so who knows.
It's pretty reassuring we're all having much the same problems to be honest - although I'm not too happy about the prospect of my clutch pedal snapping anytime soon. Those threads stop me sleeping at night.
Connor H
1,052
518
Essex
Yeah when i got the. car the rear washer wasnt connected and i assumed that it was running into a pocket of metal by the rear light, i cleared it and i havnt had any significant wetness since then but like i said before my footwells are always just slightly moist to the touch so i know its not air tight. And now ive found water in the boot, defo worth inspecting.
Oh the clutch thread, yeah funny you said that because lately i kept getting flashbacks of it so now i treat my pedal like its made of cheese hahah
Reactions: iammooks
Sl1ced
797
404
Mine seems to be leaking from the rear lights
BadBoy03
A Mk1 Is For Life, Not Just For Fun
Sep 6, 2016
772
577
Somerset
I actually drove LCR to work today all 7 miles of it ....The boost gauge fell off its mount and i picked up a puncture, Oh well roll on summer
Sounds like a typical day in the MK1 :) something always plays up! Yesterday I popped into the shop after work. Boot was fine at work, go to put shopping in and the boot catch fwkd ...sigh
LCR AL
82
49
Got bored so checked some hoses for splits and decided to spray my charge pipe black.
Not the best job but better than the oil stained look it had previously.
Sent from my SM-A405FN using Tapatalk
iammooks
1,823
1,223
If the hoses under the scuttle are anything to go by, they do get a bit brittle over the years. I'm going to pay some attention to the wheel wells in the boot, as I'm pretty sure my 12v has never worked since I've owned the car and I'd like to clean the contacts for the light.
I'm going to have a rest for a few days after the MoT - that totally stressed me out because if the car failed, it would have been all on me - but now I've got a bit of confidence back.
Just the two sets of control arm bushes, steering rack bush and dogbone mount...
And then I can finally get round to doing the turbo vanes...
Holy crap - this stuff never ends...
No sense treating the pedal as though it's made from cheese - the whole car *is* made of cheese.
And I'm lactose intolerant.
MoToJoJo
859
701
Northants
Clutch pedal does what?! And there was me being a little concerned I may have to bleed the clutch line (it's playing silly feckers from time to time, won't fully return)
Stripped out the rear bench n did a little experiment to see if I could cope without a stereo on the commute. It went well so may soon be selling my interior
Reactions: iammooks
iammooks
1,823
1,223
Oh yeah - apparently they just snap - just like that. Now I'm terrified of changing gears - just driving everywhere in first gear these days.
Honestly, this forum is great in so many ways, but it's like looking up your medical symptoms on Google and everything comes up as cancer.
Rich.T
1,611
932
Fitted a new spring and refurb kit in my forge diverter valve today.
For some reason the bottom of the piston and sealing edge on the body is slightly pitted so may replace the lot at some point.
On a side note, those of you that have these fitted. Its worth taking the piston out and cleaning it all in there.
Ive got a receipt to say my dv is only 3 years old.
And due to the grease in there going all claggy the piston WAS STICKING.
You could be losing power here people!
Worth checking anually.
Also its easy to do. I give it 1 spanner lol.
Check on YouTube if your not sure.
Rich
