Clutch pedal snapped
Rich.T
1,611
932
Happened on my 1.6 many years ago. Was very cold like with you and it kept sitting on the floor. Never did it again after that cold morning though.
Maybe caused by moisture in the fluid then?
Drove the car thismorning (at 7.30 so a little warmer) and it was fine.
Keeping my fingers crossed.
Rich.T
1,611
932
Evening all.
Thought id drop a question on this thread rather than starting a new one for a simple question.
Looking at buying a pedal 2nd hand that i can modify/strengthen.
My pedals have the holed ally plates fitted.
Anyone know if i can remove it and fit it to a non R pedal?
Cheers all
Rich
Connor H
1,052
518
Essex
Evening all.
Cheers all
Rich
no idea but my pedal was from a TT or a golf i think
Reactions: Rich.T
Rich.T
1,611
932
I took the plunge.
Got a black plastic/rubber pedal.
If i cant fit my ally pedal to it, I'll just flip it.
Have you got any pix of the damaged pedal?
Will give me an idea where to weld it.
Connor H
1,052
518
Essex
I took the plunge.
should have everything ya need
Reactions: Rich.T
Rich.T
1,611
932
Well my pedal turned up. So will look to see if it matches the one on the car.
Was it just the back of the box that broke away and the white plastic bush came through?
Need to know where to weld.
Connor H
1,052
518
Essex
Yeah thats what happened, exactly the same as in the guide. Its the tack welds that break on the box section
Reactions: Rich.T
g60stu
463
360
Reading
No they literally just bust apart quite dramatically. once the section breaks theres nothing to stop it from going against the footwell.
Another clutch pedal bites the dust. Am sat at an M4 junction waiting for the AA. Literally no warning!!
mty12345
4,114
680
bristol
He’d get an automatic.🙂
I pulled the broken pedal from the car. Ordered new bits. Can’t wait to fit them.
Mine broke last year. Seems the welds are reaching the end of their lives.
Getting that big spring in is a *******! I used 2 cable ties to keep mine compressed, then cut and removed them when it was in place
g60stu
463
360
Reading
First attempt at fitting the new pedal and I’m failing. There doesn’t seem to be enough clearance to locate the pedal recess with the white plastic bit and the push rod. Am I supposed to brute force push in the push rod to get enough clearance?? That seems kinda difficult given the shape and location of it all!?!
Reactions: BadBoy03
mty12345
4,114
680
bristol
Yeah it's an absolute pig of a job. I removed the drivers seat to make access somewhat easier. Then it's a case of trying to line everything up which does take a certain amount of brute force. I cable tied the spring in the compressed position to make it easier, still difficult though
Reactions: BadBoy03
BadBoy03
A Mk1 Is For Life, Not Just For Fun
Sep 6, 2016
778
582
Somerset
Sorry to hear this.
The only time, in my ownership, I've broken down with the boy is due to the clutch pedal going.
I had the luck of the gods on me that day though...just dropped my daughter off at school (who had an exam that morning), literally pulled out of the school, passing the multitude of school coaches & then ping. I knew where a field entrance was (next to the school entrance) & coasted enough to get the car out of the way. It was about as lucky as you could get timing wise.
I got the RAC out, who clipped the pedal in place enough for me to drive to the garage. If I'm honest, I was so glad the garage did it, had it back the next morning & had a courtesy car.
Best of luck 👍
P.s...my son scraped my rear bumper yesterday, as he pulled in too fast & too wide 😔
Reactions: mty12345 and g60stu
g60stu
463
360
Reading
Success! New clutch pedal fitted. It has taken a good couple of hours trying different methods. In the end I went with the method described on the audi sport link above. It just took a lot of manipulation. I went with the tie wraps on the spring - that worked a treat. Absolute PITA job and I hope to never repeat it, though I expect I could do it in half the time next time.
g60stu
463
360
Reading
And now for the sickener….
I’m putting the lower dash back and just discovered this in the tool box!! It should have gone back into the pedal before installation. But Everything feels ok now. Not sure I can be bothered to fit it. 🙈
I wonder whether it would be an issue??!?
  • Wow
Reactions: BadBoy03
