Unfortunately the Halo of Bosch won't protect them from the evils of "Value Engineering"
So, after 20 years, the alternator pulley seized. That put a considerable amount of effort onto the belt. Result: the belt tensioner cracked! 3 hours later and 300€ lighter, the problem was solved: new alternator core and brushes, new INA pulley, new GATES belt and new INA belt tensioner.
Reactions: Sl1ced
Me too several months ago. the tensioner doesn't last long with a seized freewheel pulley on the alternator.
You need to post a how to...
Mate it’s so easy. I jacked under the engine/box depending what you’re doing then undid it. And replaced it. I didn’t need to really disturb anything. I unplugged the coolant bottle and I did the mounting screws on that and the Ps reservoir, that’s it. Half hour a side and that was with me pissing about haha
Aaaand done the engine side today
Aaaand what a horrible thing it is too.
At least for me, all the aluminium thread came out with the bolt on disassembly.
I didn't even get the chance to overtighten it.
Bodged with a coarse metric thread helicoil kit, some old bolt and blue loctite.
No bluff too tough
Evening all, does anyone know the spark plug gap to run when doing the conversion upgrade from standard coil packs?
About to do the job now and just remembered reading a while back there's a different gap
