MoToJoJo
861
702
Northants
Whats the most you can get out of a pd150?
Was getting my car washed today in the local hand car wash. And behind me was a clearly modified Alhambra.
Had a quick chat with the owner. Sead it was a pd150 from a Leon with a 2.2d mercedes turbo, fmic, hard pipes, induction kit, air filter, 3.5 inch straight though exhaust and a remap. He quoted 350+ hp. Is that even possible? 200hp more than the factory?
Must admit, it did sound lairy lol
It's possible but without head work, cam etc he's nowhere near. PD150 injectors are only good for about 240bhp
iammooks
1,827
1,228
There's a channel on YouTube called Vory TDI and they have a 4x4 Leon that does 400bhp apparently. It probably cost an utter fortune. The amount of black smoke is inane.
Reactions: Rich.T
Nam-uk
1,277
418
lancashire.
silly cash to get to that point unless you got a garage, class though
Reactions: Rich.T
Nam-uk
1,277
418
lancashire.
In all honesty, I'm amazed there wasn't any damage. Me driving probably less than 500 miles last year probably had a lot to do with that though. I just see this whole experience as a massive dodged bullet - my wheel not falling off being the first, and the second this garage being honest enough not to bend me over and charge me hundreds for doing work that didn't need doing.
I'm so tired of crap garages. So, so tired. How is it some driveway mechanic can do a better job on my car than a bricks and mortar garage?
when i had my wheels redone and was a big company , two wheels were loose but at time thought everything other than that i.e tyre pressers , steering rake ect with tyres wide i could not move the wheels so took it into the garage i was using at time as it was doing my head in and car did not feel right or safe i just stopped driving it , i dropped it off and went back in later and they took the front cap on front wheel 3 bolts feel out and on was in a thread or two the one on rear were just loose well undid too the cap, what it was is the surface of the wheel hub was not clean or the inner and that caused them not to sit correct even though nuts tightened correct but would not think if you seen it , ballistic was not the word and i reckon it hit me hard later on as i was on motorway for a while driving with wheels like that few days later i went numb, imagine the front wheel coming off
Reactions: iammooks
Rich.T
1,611
932
It was pub talk then 🙄
He did say it had bigger cc injectors but also sead it ran 10s at Santapod.
I should have known better and apologise for my ignorance 🙈
Rich.T
1,611
932
Fitted a new badge.
Thats enough maintenance for one day.
Reactions: Dazzalcr
iammooks
1,827
1,228
If I weren't so bad with conflict, I'd have gone to the garage to tell him how badly he could have ****** everything up, but after a year, it would be so easy for him just to say the nut had come loose on its own or something. I remember the wheel being wobbly when I had my MoT last year because I mentioned to the tester that it was the only one I'd ever had changed and so it seemed weird that it was going.
The stupid thing is that I do work on my car sometimes and I'm wondering if I should be taking it to a garage instead, in case something goes wrong, but the reality is that taking it to a garage is no guarantee of safety.
At least I don't have to do my bearings now, so I might find some time later in the year to do my clutch.
Reactions: Nam-uk and Rich.T
MoToJoJo
861
702
Northants
It would be so easy for him just to say the nut had come loose on its own or something.
If that nut comes loose on its own it's pretty much always because of the tool doing it up wrong.
But yeah, best to just never ever go back to them and warn people off them (unless you know them well then go for it).
Have laughed at garages when they come up with a list of repairs for MoT. "Your sump is cracked and leaking oil" (Narrators voice: It wasn't) "Your brand new KW V3 coilovers are too stiff" (Narrators voice: Motherfu.... fine, I'll back off the factory preset damping)
Reactions: iammooks
Nam-uk
1,277
418
lancashire.
If I went up there I’d be in jail now , get it what for on the phone and all the excuses come out, I use the aldi torque wrench every time wheel are touched now not risking it after that.
Reactions: iammooks
smutts
373
188
I'm guessing what the other garage did was to take out the driveshaft so they could get to the top nut of the ball joint, rather than get the control arm off by undoing the three bolts underneath and sliding it out. So when the time came to put the driveshaft nut back on, they just noisy gunned it rather than torque it to spec and it wasn't even on properly.
When I've been working on the car this past year, I've been looking at the nut thinking it looked off, because there didn't seem to be many driveshaft threads visible and there was what looked like plastic or something sticking out one side.
Fair play to this other garage though - they could have charged me £250 and say they changed the bearing but they put a new nut on (when, as always, I have one at home) and charged me labour.
All seems fine now. I won't know until I next get the car in the air whether there's any play, and I hope they put the disc retention screw back in (little details like that are important to me) but it drives fine and means I've got more money to replace my boost pipes now.
And get this - they used copper slip. First garage I've ever found where they didn't go in dry.
It is a bonkers design that won't let a ball joint clamp get in there.
Bodgers (& me!) just unwind the ball joint nut until it stops hard against the CV joint.
Then keep going until either the ball joint pops or you brinell your wheel bearings and the ball joint pops.
Unless you absobloodylutely have to replace the ball joint, as said, undo the three M8 bolts.
Else you enjoy a really lousy time.
smutts
373
188
Doesn't seem to worry Robin Reliant drivers.
Reactions: Rich.T
smutts
373
188
New (old stock) Bosch brake master cylinder arrived on doorstep (by Hermes!.............. How?).
So that's ready for a mechanical wrestling match soon.
Will the brake booster be full of fluid? The excess being pumped into the engine oil?
Place your bets now.
iammooks
1,827
1,228
Ball joints are one of those 'easy when you know how' kinds of things, but they're still a pain, like you say, with the CV shaft in the way. I put a jack under them to be able to loosen the nut, and then I get a tuning fork splitter in there once the nut hits the CV shaft, then loosen it some more until I can get the nut out.
I only say this after undoing the three bolts first and discovering it's way harder to get the lower part of the ball joint to slide into the control arm - remembering I have the pressed arms on my FR. Some people seem to do it easily. Not me.
Sometimes experience is the best teacher.
I'm glad I didn't have to change the bearing though - that would involve getting the lower shock mount, the tie rod end, the ball joint out and the CV nut. And then the bearing.
**** that ****.
iammooks
1,827
1,228
https://www.detailingworld.co.uk/forum/showthread.php?t=386790
Not a Seat, but an interesting thread I came across. Buy the looks of it he's basically taken the car apart, refurbished or replaced and put it all back together again over the last couple of years!
I'm currently on page 13. Thanks for that, you *******.
Managed to get out today to run some Cataclean through the car. Added it to 1/4 of a tank and took it for a short drive. Doesn't seem to be any smoke coming out at low load revs anymore - there used to be a big puff when I accelerated from 30mph in third or fourth - but we'll see what happens in the weeks to come.
I wanted to run the cat cleaner through as it turns out my car didn't really pass the MoT emissions test. I won't say too much, but the garage isn't a fan of emissions testing and so applies a different test limit from Halfords and Kwik Fit. I'm grateful to them for getting it through, but I want to keep emissions down as much as possible - not least because it points to an issue in the engine if the NOx emissions are high.
In other news, my knocking sound from the rear is back, so it probably wasn't the fuel tank scuttle. It sounds like it's coming from the offside rear door, so when I replace the lock eventually I'll be able to dig around and see what's what. It's totally random - sometimes it happens when I pull to a stop at traffic lights, other times it happens when I'm just driving along. If it made the noise when I hit bumps or when I was turning, it might be easier to track down, but I'm absolutely stumped. It's not the shocks, as they're new and the bolts are torqued, and it's nothing behind the wheel arch as I took those out to fit the shock top mounts. I'll check the door strike plate and make sure the lock is tight over the weekend.
  • Haha
Reactions: Alexis27
