Digital / Virtual Cockpit retrofit yet?
Feb 2, 2022
Hello!I'm new in forum and I have leon cupra 5F 2014 model and I want to do my car virtual cockpit from analog. I want ask, can I do my leon MIB1 virtual cockpit. And if I can ,what parts I need to work it 100%?
Sep 22, 2021
10
You'll need component protection removing, correct software & dataset. You'll also need your drive mode FeCs restoring
Ye, as you wrote.. I changed my gateway but my drive mode not working... When I click on button nothing shows, can you help me with fix it? What coding in vcds or sth like that I have to do to make it again??
Sep 22, 2021
10
You can't parameterise it online as it's the wrong part for your car. You'd need a suitable donor VIN
As of January 1st 2023, you can only go online with ODIS S 10.0 or above. Meaning if you're using clone software/adapter to DIY you're going to struggle
Odis is not the problem, fec file i have in mib but i still didnt understand this files
May 28, 2023
hello :) i Have Cupra300 2018 :) Ihave VC 5F0 920 790 :) Can I make SW update to show 4th SPORT view? Or I must change VC for 5F0 920 790B ?
