Worth noting that 790/790A isn't compatible with some vehicles. Some require 790B due to an immobilizer changeWhat exactly is ''Fiber Optic cable for connection between Nav unit in glovebox and VC'' ?
No, you need MIB2Hello!I'm new in forum and I have leon cupra 5F 2014 model and I want to do my car virtual cockpit from analog. I want ask, can I do my leon MIB1 virtual cockpit. And if I can ,what parts I need to work it 100%?
Ye, as you wrote.. I changed my gateway but my drive mode not working... When I click on button nothing shows, can you help me with fix it? What coding in vcds or sth like that I have to do to make it again??You'll need component protection removing, correct software & dataset. You'll also need your drive mode FeCs restoring
You'll require the correct datasets on the gateway & your FECs restoring. This cannot be done with VCDSYe, as you wrote.. I changed my gateway but my drive mode not working... When I click on button nothing shows, can you help me with fix it? What coding in vcds or sth like that I have to do to make it again??
ODIS could make it?You'll require the correct datasets on the gateway & your FECs restoring. This cannot be done with VCDS
The FECs yes. The datasets not without having the files to uploadODIS could make it?
So… where i Can get those files? Is it possible to make it online by yourselfThe FECs yes. The datasets not without having the files to upload
You can't parameterise it online as it's the wrong part for your car. You'd need a suitable donor VINSo… where i Can get those files? Is it possible to make it online by yourself
Odis is not the problem, fec file i have in mib but i still didnt understand this filesYou can't parameterise it online as it's the wrong part for your car. You'd need a suitable donor VIN
As of January 1st 2023, you can only go online with ODIS S 10.0 or above. Meaning if you're using clone software/adapter to DIY you're going to struggle
Fec file? All you need to do is restore features online, and parameterise correctlyOdis is not the problem, fec file i have in mib but i still didnt understand this files
Okay so by Odis restore it online to prevoius options and then parameterise?Fec file? All you need to do is restore features online, and parameterise correctly
Any tutorials? Yt or Pages step by step
But if the part is from a newer model (lift), the vw server will detect that the part is incompatible, and then restoring the configuration online via odis will not workWe can likely parameterise remotely for you. We cannot however restore your features remotely
We do this on a daily basis.. send us a message if you need assistance.But if the part is from a newer model (lift), the vw server will detect that the part is incompatible, and then restoring the configuration online via odis will not work
That they do. Did mine (when I had the car).We do this on a daily basis.. send us a message if you need assistance.
