BadBoy03
A Mk1 Is For Life, Not Just For Fun
Sep 6, 2016
778
582
Somerset
Went to replace brakes - discs & pads - only to find the passenger rear caliper is totally seized
I swear, any job you think is going to be straight forward, even down to loosening a few simple screws, it never f ing is!
I replaced my antenna a few weeks back, easy enough job. That was until removing the plastic. One screw fell out, no thread, the other was stuck in spinning.
I got around that, but then replacing all the trim/plastic after I finished was an absolute nightmare. For the life of me, I still can't get it to sit tight like it was before. It was any icy day, I was sat in the boot & the swear words poured out of my mouth. 😡
Good luck m8, I feel your pain.
Reactions: Manic172 and bruceR
Manic172
Dec 4, 2018
1,467
1,616
Hemel hempstead
www.seatcupra.net
Right. If you lot can keep a secret. I have some photos of some thing that is being made for me... but these are NOT ment be be public. So if you all promis not to share or show other forums, the book of face etc.. I will post them in my build page.. but you have to promise 🤚📕💒
Reactions: Alexis27
bruceR
2,577
665
Monifieth, Dundee
Promise not to tell a sole about………….wait what was I going to tell
Reactions: Manic172
BadBoy03
Sep 6, 2016
778
582
Somerset
Not a peep from me 🙊. You won't even find me on dem sites...unless it's OF? 😂😂🤮
Reactions: Manic172
iammooks
1,827
1,228
Passed. Just need some new tyres apparently.
iammooks
1,827
1,228
Best thing about it is that it hasn't failed because of anything I've done.
When the headlight bolt snapped I didn't know if I'd bent the panel drilling it out, that and the fact the re-tapped hole was slightly off centre. How on earth do you align headlamps anyway? Turns out I didn't have to worry - about that, or the fact my front number plate is a post-Brexit UK plate and the rear one an EU GB plate. Should be an instant MoT fail that - horrifying lack of attention to detail.
Nathan penney
Active member
Jul 8, 2017
793
1,000
Liverpool
With you on the number plates there mate.
Ive been running my daily motor for 9 months with a blue EU one on the back and a plain one on the front. Don’t know how I’ve slept at night. Worse thing is I’ve had two brand new matching ones in the shed since a week after I got the car and I just haven’t put them on yet. :eek:
bruceR
2,577
665
Monifieth, Dundee
Replaced both rear calipers, discs & pads, pressure bled system but still have a soft brake pedal
Will have to look at bleeding master cylinder 2moro!!
