Hi all and merry christmas. I have a question about automatic lane change. it works fine for me even though I don't have QFK MA FUNCTION coded in controller 44 (i cant do this) but what I noticed is that the arrows only show up in additional assistant fields like in the movies. when I turn on the assistant view like in the picture (this is just an example of a view) it doesn't show it in the main one. how is it with you? the second thing is that when I hold the TA button it can't turn off or on automatic lane change. when I hold the button it just says "lane change available, hold the button longer" but nothing change. I have to do it through the menu in the radio. of course it doesn't affect the use because I don't use the assistant view anyway. thanks
Hello witek_77,
I would suspect there is some
coding regarding the lane change that you have not activated. I have been able to get the automatic lane change in the menu, but it doesn’t work for me nor can I toggle it on or off.
From what I have heard the software of my camera is not up to date, but in your case I would assume the
coding isn’t fully adjusted for lane change.
from what I know, is that when you have ‘double’ items in cluster, one of them is either deactivated or shows less, like when you show the bigger fuel gauge the smaller one disappears.
can you send me message of what you changed in
coding to have automatic lane change work?
You too merry Christmas and happy new year.
