Rear tow straps drilled. Welded. Just waiting for some spacers to turn up
Reactions: tracktoy
was doing to replace the drivers seatbelt as it wasn't retracting well but i found a trick were you clean the belt and now its like new and fully retracts without issue
was doing to replace the drivers seatbelt as it wasn't retracting well but i found a trick wear you clean the belt and now its like new and fully retracts without issue
Is that the dishwasher tablet one? I've been meaning to clean my seatbelt for ages.
No thought to strong as you can use them to clean the washing machines as its stronger than soap powder, used hot water, bit of soap powder and bit of fairy and while at it thrown in a bit of fabric conditioner lol, let belt soak in a bucket for a hour or two then give it a scrub and rinse in clean water, and dry over night also used a quick clamp to hold the belt fully out and done on a hot day if you dry it off enough it don't take long to dry out... the crap that come off was shocking even after a clean bucket rinse, i meant to do it last year its worth doing if not retracting all the time
Reactions: iammooks
