I already did thatDo you want to move the start/stop button from the center console to the steering wheel?
I am not 100% sure, but I believe that @cairus once said that Born (MEB platform) MFSW buttons send different signal than Leon ones (MQB/MQBEvo platform) and cannot be switched without some signal emulation in between.Hello, i want to do the retrofit mysqlf and came across the question if it would be possible to use the cupra born steering wheeel as it has a drive mode button and i dont have keyless go and change the touch buttons to physical buttons.
Oh okay thanks, i have the problem that i want the cupra design but also dont have DSG and there are only options with paddelsI am not 100% sure, but I believe that @cairus once said that Born (MEB platform) MFSW buttons send different signal than Leon ones (MQB/MQBEvo platform) and cannot be switched without some emulation in between.
There are Cupra steering wheels without DSG paddles but are rather rare (e.g. 5FF419091A but most of the times have white stitches and silver trim from Seat, not Cupra). You could do similar thing that I did in my car - FR steering wheel (with custom leather and stitches) with Cupra trims.Oh okay thanks, i have the problem that i want the cupra design but also dont have DSG and there are only options with paddels
Maybe i go with the paddle option and just remove them
Every other image of 5FA419091FN on the internet shows that this steering wheel has DSG paddles, e.g. here: https://www.ebay.pl/itm/355195317289
Unfortunately not, because it does not support heating. Only 5Q0953549B or 5Q0953549D directly fits and has support for heating in your case.Can i use the clock cpring partno. 5Q0953549E for this retrofit?
Okay thanks for the fast reply, then i will order a new oneUnfortunately not, because it does not support heating. Only 5Q0953549B or 5Q0953549D directly fits and has support for heating in your case.
Is there maybe a part number you can share with me?Rebuild. There may/will be problems. You'll also need new trim.
Sorry do you mean the clock spring module with that? My english is not the best?You need to check which manufacturer your control unit is from. Also you need the same manufacturer for the steering column switches
There are a lot of variables that defines stalk part number, but for Leon 3 there are two main things:Is there maybe a part number you can share with me?
So you've got 5Q0 slip ring and steering wheel with Travel Assist button.I currently have the steering wheel with part number: 5FA419091DQ
And the clock spring with 5Q0953549D
Okay thank you very much for your help, then i will look for 5Q0953513AJSo you've got 5Q0 slip ring and steering wheel with Travel Assist button.
If you have any assistant in your car (Front Assist, Line Assist, Light Assist and so on) you want to order stalks with Assistants button of left stalk with 5Q0953513AJ part number. If you don't have any assistants then you can order stalks with 5Q0953513P part number which does not have Assistants button of left stalk.
FYI this is how 5Q0953513AJ looks
