Full Link activation after software update
cairus
1,575
552
ja, über seine Toolbox... Ich habe mehrere heruntergeladen, aber meine Autoeinheit sagt immer wieder, dass die Dateien auf der SD-Karte nicht unterstützt werden
Apple-Benutzer?
Wich System? 1 or 2 SD Reader?
Jul 4, 2025
29
Apple-Benutzer?
I figured this part out. I had to put the files inside of the main folder in the root of the sd card. But now it screwed up my navigation. Still trying to fix it. It says navigation database not available. I have original card and didn’t do anything to it.
Jul 4, 2025
29
You have the New Navi Update?
I have both. I have an update and I have the original card. The original card isn't tempered with. Didn't remove or change anything on it. Before getting the toolbox to work, the updated maps on a different card worked. After intalling toolbox, it didn't work anymore.
I hope updating from MST2_EU_SE_ZR_P0479T to MST2_EU_SE_ZR_P0480T will fix it.
Tell
Probably why I don't recommend the toolbox. You shouldn't need to use the toolbox unless you jump firmware trains which you aren't suppose to.
The mapcard if it's the official one should be 4096 sector size, fat32. This can get changed by accident in a format. You need the original overall.nds copied onto the updated map file per the workaround. It's not a PC.
Latest maps
If you do loose your original overall.nds file use the one attached to this file:
But if the toolkit which I don't recommend has hacked your system in some other way... pass. The toolkit is suppose to free you up from using official vag cards but obviously if it's messed up you get no map. Then on the other hand don't use the toolkit and use the overall.nds workaround.
29
The mapcard if it's the official one should be 4096 sector size. This can get changed by accident in a format. You need the original overall.nds copied onto the updated map file per the workaround.
I appreciate your comments. And I am not going to jump trains. But the navigation worked before installing the toolbox. Both original card and updated maps on a different card. After installing the toolbox, which didn’t really do anything I hoped for, the navi just gives me the message: navigation database is not available. I just uninstalled toolbox, but without any effects. And with this navi message, I can’t go into the navigational settings eather.
Tell
There is probably a moral there somewhere. @leonlad has used the toolbox a lot. May be able to help. For a long time there were few people with experience of it. On Skoda boards it was more popular.... not too sure why apart from train jumping.
Jul 4, 2025
29
The strangest I've come across, is that the car says the original maps SD card does have the needed data, but it doesn't do anything with it.
Jul 4, 2025
29
What you have done with the ToolBox or only Install?
I tried to see if I could find some settings which I would like to change, because internet says you can change some cool things, but it doesn't say what exactly. I couldn't find anything useful for me to change except for the oil level, but it didn't do anything. I could check it, but after rebooting it was unchecked again. So I decided to uninstall it again. Oh and mirrorlink which didn't work...
