Full Link activation after software update
cairus
1,575
552
Patch tsd.mibstd2.system.swdownload to accept any metainfo2.txt
Patch tsd.mibstd2.system.swap and generate EL
With unlocked SD Card but Not the OEM Navi Card
I Take No warrenty
Reactions: Rogier
Jul 4, 2025
29
Normaly you can force now in the Service Menü unser SWDL
You mean to update? I tried with all the files installed on the sd card, but I can’t push the start button like you can with the toolbox installation.
Jul 4, 2025
29
In the SWDL Menü you have To Change IT manuell from No To Yes
I can’t select the “software download manual download” button. Only the “start download” button works. After selecting this option I can choose the source “SD-card” but after this I can’t do anything. I can see all files, though.
Jul 4, 2025
29
So I installed the update. Unfortunate no change in navigation
Jul 4, 2025
29
I even found a newer version of the oem in my old mib(1) unit. Also doesn’t do anything. Didn’t even realise I had this.
cairus
1,575
552
When you have done a Firmware Update, a Lot of Funktion are locked in your Case. Because mib2 in mib1 Car.
You have To Patch IT.
I would Patch all
Jul 4, 2025
29
Everything works, expect the navi… plus I didn’t do a firmware update before now. Only installed the toolbox. Which is ****. I just tried a firmware update in the hope my navigation would work again.
cairus
1,575
552
First Picture of SD Card is Not Locked.
But i think it IS not the solution
