Patch tsd.mibstd2.system.swdownload to accept any metainfo2.txt
Patch tsd.mibstd2.system.swap and generate EL
With unlocked SD Card but Not the OEM Navi Card
I Take No warrenty
Reactions: Rogier
In the SWDL Menü you have To Change IT manuell from No To Yes
I can’t select the “software download manual download” button. Only the “start download” button works. After selecting this option I can choose the source “SD-card” but after this I can’t do anything. I can see all files, though.
So I installed the update. Unfortunate no change in navigation
I even found a newer version of the oem in my old mib(1) unit. Also doesn’t do anything. Didn’t even realise I had this.
When you have done a Firmware Update, a Lot of Funktion are locked in your Case. Because mib2 in mib1 Car.
You have To Patch IT.
I would Patch all
Everything works, expect the navi… plus I didn’t do a firmware update before now. Only installed the toolbox. Which is ****. I just tried a firmware update in the hope my navigation would work again.
First Picture of SD Card is Not Locked.
But i think it IS not the solution
