I NEED HELP PLEASE!
Car: Leon fr, MK3, 2014, 2.0 TDI, 184 bhp
Issue: Coolant is not staying in expansion tank properly. All the coolant stays in the system more often than not. Once I fill the tank up, coolant doesn't get sent back to the tank/stay in the tank when Im driving and once I have finished driving.
It's not leaking anywhere either cause when I get a warning for no coolant in the tank, and I top it up to the minimum line. After a while the coolant levels are super high and it goes way past the maximum line, right to the cap. Then it eventually gets forced out as it is too much coolant in the tank.
I also hear water gurgling noises from behind the middle vents (where infotainment system is). This noise will be heard as the ignition is turned on. When the ignition is turned off and key taken out, the noise will go on for 30 seconds or so.
I have no other symptoms of this unknown problem. I have no coolant leak in the cabin, no white sludgy oil on the dip stick or oil cap, coolant is nice and reddish (when it gets back to the expansion tank).
Please help me with this. Has anyone faced this issue???!!!
Or has anyone got any helping words/solutions????!!!
