I think the end conclusion is regardless of oil youve got an terminal problem which will be resolved by
A.engine rebuild
B.second hand engine
C.sell the car for spares/repairs and buy another
D.set it on fire and claim on insurance lol
This. Plus E. do the 1000km the mechanic suggested and see how it goes (which costs nothing). Failing that A or B because if it's failed a compression test on multiple cylinders, the piston rings have probably had it. But it does have a fair few miles on it. Not sure how much you'd get back from D LOL.
My bwj ko4 tfsi suffered oil consumption(400miles per 1litre) before rebuild , mileage was 79k when i got it
My bwa ko3 tfsi in my octavia vrs suffered oil consumption(600miles per 1litre)48k miles 1 prev owner full skoda history
My friends a3 tfsi you guessed it suffers with oil consumption
Vag quality is not where it used to be
The newer 2.0tdis are not as reliable as the older 1.9s
You'd happily buy a 1.8 20v t with 100k+ but a 2.0tfsi you'd steer clear
bagged fr , k1 rep , 19s
They will tell him it will need a rebuild or say its within tolerance just top it up regulary
Guys I went to the dealer today to change the spark plugs as they requested below the photos. What do you think?
Is the engine burning oil?
Maybe it's just the angle of the photo. But that gap looks massive.
Reactions: mty12345
It doesn't look as if it's burning oil to me, the gap does look very wide and looks like the mixture is a bit on the lean side.
Hi All,
I do have same issue with Seat Leon 1.2L - Petrol - I had this car for 7 months now , replaced oil+ filter - mileage is 140k. I had first warning check oil level , checked and there wasn't any oil on the stick top up with one liter after that in 5 weeks I decide to change oil+ filter. Around 6-8 weeks got message again "check oil " and was no oil!. Top it up with another one liter and again after 6-7 weeks like today give me message again.
Inspected there is no oil leak at all - is this do with gas kit / spark plugs ?
please let me know if you guys had this issue / what will be the problem ? thanks
Hi ,
Have you sort this out ?
@sewar I would start here:
Your plugs can't cause oil consumption. those plugs were just knackered.
Surely the plugs can only burn oil if it the oil is already getting into the combustion chambers, either up from the cylinder bores or down from the valve stems?
I agree about the plug condition though.
