Ibiza CupraRS 251bhp & 253lbf-ft
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Power.
Torque.
Power Comparison between APR-BLUE(2004), Ko3s-GREEN,(2005) no FMIC, Mani, 3"dp Ko3s-RED, (2006) current spec.
Torque Comparison between APR-BLUE(2004), Ko3s-GREEN,(2005) no FMIC, Mani, 3"dp Ko3s-RED, (2006) current spec.
All 3 dyno runs were done in either november or december with the ambient temp less than 8 deg C.
Bogwoppit
1,085
Lincs
Cuprabaz , I see your logbook says yours is a 5 door as well, not just mine then.
Impresive graph by the way.
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
blimey thats good going
you got to be chuffed with that :thumbup:
Very happy indeed mate. :D :D The car is still running the original 16psi map that Jim Curley did. But since fitting the FMIC, 3"dp and Chunky mani it now hits 20psi then tails off to 18psi. After fitting the mani the low end torque is really impressive and the extra shove up top is equally as impressive.
Hopefully that together with the new transmission(once it's finally fitted:redface: ) and some R-888's will see it bust that 14 sec brick wall i've been bouncing off of for that last year!:cry:
When the car was on the rollers Russel(Wallace Performances new gaffer) used a wide band lambda was to see how the fueling was and it was perfect with room for a few more psi without any worries.
Pete i think they all do ;)
