kidinspace
Service Desk Specialist
Dec 3, 2008
1,227
Glasgow, Scotland
www.flickr.com
I want to change my fuel filter, but I don't know where it is...
Dug this up from VagCat, but this doesn't say where on earth it is!
Is the same for all the petrols? - It simply says "otto engine".
I know in VAG diesels the fuel filter generally is in the engine bay, so this diagram has to be for petrols.
Does anyone know where this is on the car?
Fuel Filter is number 10.
.G.
I think that its back near the tank - I've never changed this yet on my wife's 2003MY Polo 1.4SE, but I do seem to remember that ETOS makes some sort of comment about with or without a one way valve or something - just to make it akward - also it seems to need a release tool.
I see that there is a "choice" of "9" or "10 + 11 + 12" - "9" is a plain filter element, "10 + 11 + 12" has the extra bit fitted - some thing along the lines of what I've mention above - what ever the extra bit is?
On the 1.2 Ibiza the fuel filter was infront of the OSR wheel just behind the sill. Didn't need any special tools, the fuel pipes were push fit, you just needed to squeeze the connector sleeve then pull, my filter was going a bit rusty so the fuel pipe was a bit tight. Just have to be careful as the pipes were still under pressure when I did it but that might have been because I changed it about half hour after driving.
Dash, so it sounds like I don't need to buy a special tool (don't worry I'll find some other specialist tools to buy!), any comment to make about the lump shown that gets fitted before or after the filter on some cars?
take the fuel pump fuse out ,run egine till it stalls, remove filter now as it not under pressure any more, replace filter and fuse then start the engine
What is the part number for your fuel filter???
When I ordered mine today from Seat I was told that there is possibly 3 different fuel filters for my car! This is after giving my chassis number.
However the parts manager did say that if it's not right then they would change it no problem.
Still haven't got under the car to find it to try and get a part number off it, might go and do that later...
My fuel filter is listed as 6Q0 201 511 on the box and has 6Q0 201 051 (A) and 6Q0 201 051 on the filter itself.
Anyone else had a similar experience?
.G.
Do you know what fuse this is?
Had a look in the manual but nothing is in there as "Fuel Pump" .
Here's the list...
  1. Free
  2. ABS / ESP
  3. Free
  4. Brake Light, Clutch
  5. ECU (Petrol)
  6. Dipped Beam (RHS)
  7. Dipped Beam (LHS)
  8. Mirror Heating Control
  9. Lambda Probe
  10. "S" Signal. Radio Control
  11. Free
  12. Height Adjustment Headlights
  13. Level Sensor / Oil Pressure
  14. Additional Engine Heating / Oil Pump
  15. Automatic Gearbox Control
  16. Heated Seats
  17. Engine Control Unit
  18. Instrument Panel / Heating and Ventilation, Navigation, Height Adjustment Headlights, Electric Mirror
  19. Reverse Light
  20. Screenwash Pump
  21. Main Beam (RHS)
  22. Main Beam (LHS)
  23. License Plate Light / Pilot Light for Sidelight
  24. Wipers
  25. Sprayers (Petrol)
  26. Brake Light Switch / ESP
  27. Instrument Panel / Diagnosis
  28. Control: Glove Compartment Light, Boot Light, Interrior Light, Sun Roof
  29. Climatronic
  30. Free
  31. Electric Window (LHS)
  32. Control Central Locking
  33. Self-fed Alarm Horn
  34. Current Supply
  35. Open Roof
  36. Engine Fan / Ventilation
  37. Pump / Healight Washers
  38. Fog Lights, Rear Fig Lights
  39. Control Petrol Engine Unit
  40. Control Diesel Engine Unit
  41. Fuel Level Indicator
  42. Transformer Ignition
  43. Dipped Beam (RHS)
  44. Electric Window, (Rear LHS)
  45. Electric Window, RHS
  46. Control Wipers
  47. Control Heated Rear Screen
  48. Control Turn Signals
  49. Lighter
  50. Current Rain Sensor / Central Locking
  51. Radio / CD / GPS
  52. Horn
  53. Dipped Beam (LHS)
  54. Electric Window, (Rear RHS)
.G.
your furl filter will b fine mate, my bro said they changed the part number on them after a certain period, you will either have old stock or newer stock,
Well that's good to know. :)
Have you done yours yet? I serviced mine last night, didn't do the filter in dark, not sure when I'll do it...
.G.
all getting done one saturday i believe, gonna take it too my bros work and get it on the ramp, gonna check that damn spring aswell, rumbling is annoying as fook.
Changed it this morning, petrol burns your eyes as I discovered, also doesn't feel great when running down your neck either! :lol:
Need a new screw for the plastic holder that retains the fuel filter as my screw is now rounded out... Apart from that the whole thing was done in under 15 minutes...
.G.
.G.
i thought a man of ur intelect would know these things haha, looking forward to see if theres a fuel difference
.G.
Yes, its worse in hot weather, also DERV tasts funny and again in hot weather feels horrible when you seem to have soaked yourself from head to foot, brake fluid is not so good in eyes or a lot on body and, strangly enough curdy battery acid sulphates does also make your eyes sore - sore enough to stick your head under a cold tap with out worrying about if you like doing that!
I think that its all down to taking reasonable care - oh no please don't mention risk assessment - what is that.
Trouble that I had with the Passat filter was also that the bracket retaining screw was a bit rusted up, strange that when the filter gets changed every 60,000 miles or so, also the screw points up so the extremely long thread gets loaded up with crud - and I seem to remember that the nut is welded onto the bracket - well it starts off that way!!
.G.
I found out the same thing under my camper, my neighbor had to drag me out. a cold shower & a trip down A&E later I learned a valuable lesson DOH! :wtf:
