ahem..that's my car :p
better pic:
:redface::redface:
Right then just knocked up a list of this years expected money burners
Jetex cone filter
FR3 engine mount kit
Wheels and rocker cover powder coated smoked chrome
Carbon coilpack cover
ECS coil clamps
ECS N75 valve
Short shift
4 Bar FPR
Diff
Custom intercooler pipework
DV Spring kit
Vag com (full version)
10mm spacers on rear
Service
Brake fluid
Baffled sump
Hybrid KO4
Light protectors
SCN sticker
Rikko
Looking at the Peloquinn from jabba mate why do you recommend something alittle better bud
So this wavetrac willie sounds more like how a traditional limited slip diff would work, albeit more technical, rarther than torque biasing, sounds good in the description, my only concern is how it "locks" up and transfers power to other wheel, would it be smooth or harsh, pulling car from side to side?.
From speaking to 'others' who have this fitted its as smooth as.
I'll have mine in and tested by March so I'll do a full write up on it.
as lee says, the cable used to locate on the pin to the left (in the pic) of where it is now. I drew a line between the pin and the pivot point; then drilled a hole 40% of the distance along this line from the original location to reduce the shifter throw by 40%. I then threaded this hole, inserted the bolt, then a nut the other side, cable on and then another locking nut :)
Subframes should arrive tomorrow so I can fit Corbeau Carrera recliners
Spray and fit side skirts
Redo calipers
German plates
Rear upper strut brace
Good detailing of car and cleaning inside
General maintenance
If I can afford it I'd love to hybridise my ko3s and fit a LSD but that's wishful thinking and I'm not bored of the recent stage 2 yet.
EDIT:
Oh and THS dog bone mount
Rear whiteline ARB
I really like this mod. OK, so it's not fully adjustable but it's not £75 either.
With more time it could be made to be adjustable; simply drill out the old pin and create a slot instead of the hole I drilled. You could then slide the bolt and lock nut to the desired throw length and tighten to hold in place.
