as lee says, the cable used to locate on the pin to the left (in the pic) of where it is now. I drew a line between the pin and the pivot point; then drilled a hole 40% of the distance along this line from the original location to reduce the shifter throw by 40%. I then threaded this hole, inserted the bolt, then a nut the other side, cable on and then another locking nut :)
Interesting thanks.
Might have to try and get hold of a replacement so I can do it without taking mine off the car first.
Guessing a new OEM part would be too expensive?
Are all 6 speed ones the same?
A quick update for planned mods to go on during next couple of months:
  • Weitec coilovers
  • TT front wishbone rear bushes
  • New OE front top mounts
  • THS engine mounts
  • 4 Wheel alignment
  • HIDs
  • Forge FMIC
  • Forge MAP pipe
  • Blueflame TB exhaust
  • 4bar fpr
  • Rear tyres to the front and new GY asyms on the rear
  • 23mm R32 front arb kit
  • 25mm rear neuspeed adjustable arb
  • Revo 2 software
Anything else you think I've missed that I might need (except for a new credit card as mine is on fire!)??
- 01M Transmission Friction Plates, etc (Rebuild)
- CV Joint Bearings (Inner)
- Suspension rebuild kit (Joints/bushings)
- Intake Pipe Polishing
- Redo exhaust system (Ditch the custom and get a proper real 2.5")
- Redo silicone hoses (Vacuum Hoses, Radiator Hoses)
- Redo interior bits (Colour-code - Steering, Handbrake Gaiter, A/C Vents)
- Redo front headlamps (Change lens, LH/RH Pattern, CCFL rings)
- Bodykit, fitting, etc. (Wheel Arch/Lower Engine Cover)
- Respray wheels and brake calipers
- Clean the engine
- Polishing and waxing
Couple grands to go, :doh:
Full custom exhaust (Welsh Coast Customs)
Replace all hoses for red silicone ones
Make rear brake calipers look pretty
ECU remap
For me, there's the following definites...
1. Finish off white LED interior lighting project (rear passenger, vanity mirror lights, glove box needs replacement). Rear passenger lights are going to be an ar53!
2. Steam clean interior and bring some of the dash plastics back to a nice deep black
3. Complete headlamp bulb upgrades (dip beam done, just high beam and side lamps). Also doing number plate lights and reverse.
4. Front bumper and bonnet prep and respray - they look as if they've been through a war!
And then the maybe items...
5. Upgrade clutch
6. Custom remap
7. Sort out N/S front door bass related vibration and EQ front speakers to handle more slightly lower bass frequencies.
8. Pull-down widescreen TFT from the roof, complete with one off iPod control mod for video (testing to be completed soon)
9. New shocks and bushes if they start to get bad.
10. Front brake upgrade
Hold the press.... all my plans have changed!!!
Got a mint mk3 now, just underpowerd so now untill june (GTi Inters) is all about big brakes and a dirty 1.8t to be fitted!!! (which if anyone has one going cheap i'm all ears :whistle:) also need either a mk3 16v box/ ibiza o2j and lots of mods! or a spare AUQ so i can nick the Leons lump lmao!
Porker rims... :-o
1.New back box
2.Stage 2 Remap
3.Tidy up my engine bay
4.Lowered 40mm
5.Boost gauges
Betta get saving then
First thing my 60k service by Audi £300
Stage 1 or 2 revo remap
front mounted inter cooler
silicone hoses
upper s3 strut brace
uprated engine mount
new discs
short shifter
polished charge pipe an inlet manifold
wish list:
k04s turbo
uprated big brake conversion
hopefully full respray by the end of the year
well to keep it on topic
i have these but yet to be fitted
1) Weitec suspention kit with all the mounts to compliment along with all the allignements
2) all interior L.e.d's ordered and awaiting delivery
3) Oil catch tank
4) EGR delete pipe & pipework (have some already )
5) Nomad twin pillar pod with boost and oil temp gauge to be fitted also have a blitz one , but cant find a matching oil temp one
6) carbon vinyl to sort the S badges out
7) Momo Gearknob & a new Gaitor
8) fit upper S3 brace i have
and a good fcuking clean , its bogging , but way too cold to attempt it
cant think what else i already got
And theres always a list of wants :)
have the forge quickshifter but am thinking of the side to side to match the front/back one i have on now
also need uprated brakes as OE ones are close to limits
well al little update to mine
weitecs fitted and all the bits to go with it , just need alignments done now
Bought & fitted a W8 Light which was a little unplanned :blink:
Leds turned up fitted all exept rear curtsey lights and glovebox
also done the rear number plate into leds
S badge is off and being prepped for the vinyl and a little paint should be done by next week
Boost & oil temp is almost there , cables hoses run , just not completed yet hopefully done next week
x 2 new tyres which was def not on the cards so soon [:@]
so a quick reveamp
i still need to complete
) Oil catch tank
5) Nomad twin pillar pod with boost and oil temp gauge - halfway there
Looking at new pressed plates
Def Need brakes all round
MOT Friday
still waiting for that clean :whistle:
Still waiting on Seat getting the right ones to Sere. Dave says that the other day he was still getting the wrong ones... I've not got the paintwork sorted yet so no new badges going on yet anyway, but I'd like to have the right one in my hands so I can let you have the other
ohh ye forgot about that one :)
ye am waiting to get mine tidey clean and other priorities sorted before worrying about the badge
for some reason my fuel flap solenoid stoped working (see other thread if needs be ) so have to sort that , as we got another temp wire there for now
plus desperate to get other bits done now like the gauges etc
