phil_m
126
Suffolk
Is it possible to run a AFR gauge of the AGU non dbw Lambda sensor or will i need a seperate wide band sensor.
Thx
phil
Yeah thats what i thought, does it matter where on the exhaust i put the sensor as i have a spare hole on my d/pipe.
Mine is only about 6" away from turbo, i take it has to be 16" to stop it getting damaged, so i guess i will have to get another boss welded in.
they say 16" away and between 10 and 2 o'clock. i guess its due to heat being too much any closer and having it at the top stop any condesation build up.........thats just an assumption tho
Thx
phil
you can tap into the narrow band yes, but it is at best a crude indicator and will flick from weak to rich continually - ok if you like disco lights :p
i got my zeitronix for £120 iirc. and for what you get it is great. imported it from canada.
the option of a 52mm guage is now available.
every rolling road ive been on have commented on how accurate it is compared to their one.
HoocH
HoocH
for the full zeitronix set up including in dash display your looking at £329 delivered from a uk supplier. £120 is probably cheaper than the uk distributer buys them in for:confused:
