daves ibiza
hi guys ive had my oil pressure gauge now for about 8 months ive done a search and didnt come up with much apart from one showing how to do it but it isnt same engine . do i have to buy a sandwich plate ect and screw into there . i need this done as im going hybrid and woul want to keep an eye on pressure can anyone shed some light please will be a great help many thanks
dave
depending what sender unit you have, they usually just screw into one of the spaces around the top of the oil filter...
i had a blank on mine and so just unscrewed it and screwed the sender unit in...
i did however have to tap the hole out to a 1/8 NPT thread before screwing it in
so i wont need sandwich plate mate . you got pics of where i screw it in to many thanks
not the most ideal photo but you can see where they would go, where circled...
the one furthest right is on a T-piece which you can always get if you dont have a space with an unused sensor in...
awww wicked mate so i just screw the thing i got into one of the circled up above many thanks again bud
what engine is it that you have...
more than likely the thread in the engine will be an m10 x 1mm thread
depending on what sender unit you get you may need to buy an adapter piece, to convert the thread match, or buy a tap, and tap the hole out to whatever thread you need
1.8 20v t engine code ayp i hope i dont have to tap as i no im no good at threads lol:D
i leave that to my brother inlaw as hes the electrician and mechanic lol
