Nice one mate. Standard boost should be about 10psi.
Cheers, but the P-Torque should add a bit more right?
What type of Gauge is that? Im after a Boost and Oil Pressure gauge and havent found any I Like, the one you have lights up how I want![]()
Cool, mine should be around the same then I hope. I'll have to get someone to stare at it while I floor it![]()
You have to look at the swept area of the wiper.... Find where the blade stops and measure 40mm into the screen, if there is anything in the way after that then it's a fail.
Ive never heard of a car failing a mot because of pillar pods! I guess if u had a nod of a tester! but really if its subtle then whats the problem.
I dont use pillar gauges as i dont like the way the obscure your view but thats a personal thing really.
Basically yes or take then out at mot time
Ive fitted the gauge in one a of the vent holes with a carbon panel and it looks mega just need to get it plumbed and wired in now![]()
Any pics?
so how did you guys wire your gauges then i hear some people used the headunit ? any pics of this?
It's a very good question.
I think it depends alot on the vacuum hose diameter - different vacuums have different diameter hoses, however you'd imagine them all to be the same size!
Will you be taking the vacuum hose from, for example, a Dyson or a Henry Hoover?
The Vacuum cleaner itself can be recycled, as you simply purchase a new hose for it.
