Brake light issue - please help
nicko16
89
Hi all,
I'm in need of urgent help, my preheating system light started flashing yesterday and i found that my brake lights had stopped working completely.
I checked all the bulbs and they were fine, even tried changing them to be sure.
I've just tried changing the brake light switch but now the rear lights and upper brake light remain on constantly even with lights off and ignition off.
The light initially cleared but has just come back on and the symptoms now remain the same with both the old and new switch.
Any ideas would be very very appreciated.
Nick
nicko16
89
Will try and get the fault codes ASAP.
Bought a new one and tried to fit without know the exact method, does this mean ive broken the switch? Could someone explain the correct method?
marshyc
299
Huddersfield
Yeah that's the one.
One of the switches is alot more difficult to fit than the other. I did mine recently but it was the easier of the two and a doddle to fit.
If yours was the same switch as mine then I would get it VAG-COM'd as you may have a fault or some wiring shorting out.
nicko16
89
Sorted now, first i bought the complicated b-d style switch and fudged it. Later that day i bought the simple a type which worked a treat
Many thanks for your replies MarshyC
