Coilover quick question
Aug 24, 2007
800
does this rear spring look right ?
Part of me thinks it may be upside down or something else paranoid :shrug:
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
looks very condensed together to me... how low is that set?
also yeah id say it was upside down, must be bouncy as feck like thats
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Did you fit these yourself?
Can you see the rubber mounting piece between the spring top and the chassis nipple?
I'd say there on the right way but perhaps too soft a spring rate as there doesn't seem like much room for movement there
Aug 24, 2007
800
Got the fitted by a local mechanic Willie.
Weitecs with brand new top mounts, but the old sleeves and bump stops.
Tyres are nearly level with the arch lips, so not too low ;)
Aug 24, 2007
800
I did wonder if removing the platforms would open up the springs.
The wife says the ride height is ‘nearly’ low enough !!!
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I'm pretty sure my rear springs are on the other way around with the coils toching at the bottom :blink:
Did you emove the metal ring before you fitted the bottom spring cup adjuster?
jonesy118
388
Cheshire
I'm with this guy^^
Not done the suspension on my LC, but all other cars i've done, clio, fiesta etc.. the spring is progressively wound to be closer coiled at the bottom.
Aug 24, 2007
800
pretty certain the upper part of the spring, as fitted, is not ground flat though ???
Aug 24, 2007
800
thanks Dave, thats what i thought :) The flat face must go against the adjuster as it has a bigger surface area.
tedvagas
394
cleveland
Are these Weitec gt coilovers?
Ive just fitted some on my lcr this is the correct way round , the spring will not sit the other way round because the top coil is to small to pass over the hight adjuster it does seem odd but when i looked in the instructions it was correct:)
Aug 24, 2007
800
the very same mate :)
Looks like the progressive part of the spring is the other way up compared to Adam's red ones.
