The
problem should be the degree of accuracy you need so that the inner removing/fitting plate is exactly the correct size to extend out to almost the edge of the bush outer liner but misses the inner surface of the console. It will be very easy to end up pulling the bush in at an angle and it will seize then maybe crack the console if you don't give up after it has jammed. The correct type of tool uses the small bearing bolt hole as an alignment/
guide point to stabilise the tool and stop this happening,m this is why lots of "two bit" garages don't risk changing these bushes - they end up costing for fitting new consoles complete with bushes, it seems! As for me, I read too much about what could be wrong and "bottled it" especially as I was going to fit Cupra bushes, strangely shortly after that time, a small company launched a tool to do this job on the car - well it was intended to be used with the softer standard bushes - but they seem to have vanished and their site has been closed down
