has it seized Dave?
Nae good Dave.
Got warranty on this?
Bad times mate :(
Thanks for the concern guys.
It definitely wasn't running at the last RR day. I adjusted it the night before - I'd been meaning to do so for ages. It is supposed to be adjustable from 150 psi to 180 psi, but I think I've way over-adjusted it s- o it was very restricted and I reckon it's burned out.
I've had it nearly two years. The race is on to get a replacement before 27th June RR day at Awesome.
:( not good dave. Hope you get it in time mate. Was not running on the last RR day? Was that not a while ago? Did you not notice the meth lasting a long time :)
Last weekend, Nick.
I really need to get a fail safe device to cut the boost if the wmi stops flowing, I'm lucky nothing nasty happened because it was running a shedload of advance.
Oh no Dave. This means your going to have to get a deisel :lol:
Even though its a very long way I will try and make it to awesome.
Last weekend, Nick.
Iv advanced mine now and like the sound of this device? How does it work? Flow meter linked up to somthing?
Yes please :) i was thinking about this whilst straitening my hair, surly you would need some brain behind it, as it not flowwing all the time, and you would need the brain to know what boost you are running. Then the brain can go Oww over X PSI and yes im getting a nice steady voltage from that spinning thingy so ill keep the solenoid where it is. Or does over straightening your hair make you over think? :)
Power only supplied to the flow meter when power supplied to the pump. :)
I been thinking about this and i still cant see how it would work :( But i trust you know what you are talking about so ill sit here nod and smile :)
