Tried again today n still no luck, have to get a lead if can't find someone in the area lol
Sent from my GT-I9505 using Tapatalk
The first time you put it in reverse with the switch on L, you have to set your mirror in the position you want it to be when in reverse, from then on it will dip in that position when you put it in reverse.
yea i know that but when I start driving it doesn't reset and stays in the dipped position. so I can only guess it's turned off.
According to the latest seat handbook you turn the knob to position R and dip the passenger mirror!
L is for LHD cars
So try using R instead
Its L on my RHD ST (uk spec)
Goes back up to normal when going forward over 10/15mph.
Took some fiddling when I first got the car, works like a charm now.
Sent from my Nexus 4 using Tapatalk
L is for LHD cars
Actually there is a Typo in the manual it should read L
Hey guys, have any of you heard of or used this cable from ebay?
http://www.ebay.co.uk/itm/VAGCOM-12...iagnostic_Tools_Equipment&hash=item19ef3a61cc
Quite fancy being able to do this, got a few things I want to do to my Leon, and my dad wants some stuff done to his Passat CC. So any advice would be good :)
J
Almost everybody in this forum uses this kind of cable. But the cable at your link is very pricey. I advise you to buy this 12.12 VCDS cable from Aliexpress. You can buy it approximately 20-25 dollars including shipping. Be careful when choosing. It is better to buy the cable which can be used with original VCDS software. For example:
http://www.aliexpress.com/item/-/1698625688.html
Turns out I was wrong on this one when I tried again it worked. Seems you have to give it a few seconds to load first. Alternatively my cable is dropping the connection
Ok so that cable in your link does that come with the software or where do I get that?
Latest original software version is 12.12.2. But you have to use the version 12.12.0 with these cables. There is no cheap cable like this that can be used with version 12.12.2 for the time being. Here is the link for original version of this software:
http://download.xcar360.com/vagcom-vcds-12-12-en.html
All these cables should come with a disc containing the software
Yes this is correct. Also use a laptop without an active connection to the internet otherwise the software will auto update and disable your cable.
I'm looking to get a cable to check if the control unit in my 2007 Ibiza (6L) is a 6Q0 or 6Q2, and then hopefully install and enable cruise control.
I've found one on Amazon (Google for "B001C1MNTM" and you'll see) which is well reviewed and has Prime delivery! Would this serve my purpose or should I order from China and wait?
Guys i'm buying the cable from Aliexpress, is this the one that everyone is getting?
sold by Future Titan Business Co.,Ltd
Item no: 1959338771
sorry i cant post links.
