Tried again today n still no luck, have to get a lead if can't find someone in the area lol
Sent from my GT-I9505 using Tapatalk
The first time you put it in reverse with the switch on L, you have to set your mirror in the position you want it to be when in reverse, from then on it will dip in that position when you put it in reverse.
According to the latest seat handbook you turn the knob to position R and dip the passenger mirror!
L is for LHD cars
So try using R instead
Hey guys, have any of you heard of or used this cable from ebay?
http://www.ebay.co.uk/itm/VAGCOM-12...iagnostic_Tools_Equipment&hash=item19ef3a61cc
Quite fancy being able to do this, got a few things I want to do to my Leon, and my dad wants some stuff done to his Passat CC. So any advice would be good
J
Almost everybody in this forum uses this kind of cable. But the cable at your link is very pricey. I advise you to buy this 12.12 VCDS cable from Aliexpress. You can buy it approximately 20-25 dollars including shipping. Be careful when choosing. It is better to buy the cable which can be used with original VCDS software. For example:
http://www.aliexpress.com/item/-/1698625688.html
Ok so that cable in your link does that come with the software or where do I get that?
All these cables should come with a disc containing the software
Yes this is correct. Also use a laptop without an active connection to the internet otherwise the software will auto update and disable your cable.
Sent from my Nexus 4 using Tapatalk
