I wouldnt bother if i was you but:
There should be a small fitting which will go in where your fuel pressure regulator was (right hand end of the fuel rail).
Then find a place to mount the valve and connect it up. This bit im not sure about but should be by the end of the week (going to rip one out of wilz's cupra as its running like a sack of ****!).
Have a look at his thread if you need pics of hows it connected :)
Do you have a guage for it? it may just need setting up properly just to get the car to run right, waste of money in my opinion to what i have read on here.
Its actually a rising rate fuel pressure regulator/adjustable fuel pressure regulator.
But im just a pedantic bugger :p
Stage 2 Revo Required is:
4 bar Fuel Pressure regulator (only required on K03 based cars not K04 cars with larger injectors)
Turbo back exhaust with testpipe or highflow catalytic convertor (2.5"-3.0" diameter exhaust recommended)
Recommended:
Cold Air intake (from stock MAF to front of car)
Turbo inlet pipe (Samco turbo inlet hose)
Front-mounted Intercooler (This is a BIG improvement for all cars)
i have all the above on the car expet the 4 bar Fuel Pressure regulator so you lot think i would be better to not to put one in??
