Front Mount cooler info needed
jwfcms
384
UK Yorkshire
Hi, im thinking of buying a front mount intercooler
Firstly id like to know what size intercooler would be best. I have looked on the forge website but there are no dimensions. so if anybody has one or could recomend a size or anywhere to get a cheaper front mount cooler from?
Has anybody got any pics or is there a fitting guide or pics on here that anybody has done, eg has anybody fitted a kit other than forge which they have pics of or even the forge one so i know where to route the pipework
Where do i need to route the pipe work? And what pipework would i need.
Nobody else but forge seems to offer a kit, seems a bit pricey seen as i can get a intercooler for around the £100 mark then get some pipework to fit it up and make some brackets to hold the cooler..
GREY 225
Jim R
Oct 15, 2006
445
Pro alloy do one for LCR too.It aint cheap but its a great bit of kit.Good for 300+ hp easy.
Id be carefull buying cheap intercoolers,could end up with something worse than youve already got.
The two main intercoolers available are forge or pro alloy,both kits come with all the required piping/brackets and are purpose designed for the LCR and fit without any issues.
Neither kits are cheap though but they are very good quality with regards to the end cap design,welds,and materials used.
Ronin225
4,652
22
Worcester
Nev_LCR has done a guide on how to make a custom front mount with nearly everything bought from ebay, might wanna have a search for that.
On the forge website there is a guide to fit one with pics to give you a good idea of the piping route
dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
Is it worth fitting one on a 235 bhp Cupra? I'm thinking about a bigger turbo in the future but will I notice any kind of different (good or bad) by fitting one now?
Nev_LCR
Gone... but not forgoten
May 16, 2007
1,271
Ipswich, Suffolk
i would say yes and no, yes for the bigger turbo, and no do other mods first, (turbo back system, remap, hoses,)
it does make a difference, it keeps pulling higher in the rev range, i didnt think it would but you can notice it, where it would usually die off it doesnt,
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
if going BT in the future the pro alloy one is very good for above 300bhp. it has a straight through design rather than in/out same side like the forge that got restrictive on my car around the 290 mark
B3LSY
i got this one from forge an its been great even the crash bar has holes in it for air to travel threw
dainott2105
Nov 4, 2006
685
swansea
I have a full system with a racing cat on mine (understand that I will have to change the system when I change the turbo). Also been remaped and important hoses changed. It's a Cupra not the LCR so doesn't have the pipework there for a straight through intercooler so would you recommend that I wait until the big turbo and then get a straight through or would the same side forge unit be ample with a bt.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
id wait until you get the bt and get a straight through at the same time. with the forge cooler on the car only made 290 odd running 1.7bar of boost. changed to the pro alloy and got 320bhp for 1.5bar. the forge was sent back and tested to 32psi... no leaks. so its more down to the pipework runs ect.
BT will need a freer flowing style cooler.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
but to spread the costs you could get a second hand BAM (225 BHP) intake manifold (passangers side throttle body) and Forge/PA FMIC now then that will save the big hit when it comes to BT time
milli
114
west midlands
hi, i am have just ordered my forge fmic kit and was wondering do you get these pipes in the kit as circled in the pic, or do you have to buy them seperate?
dainott2105
Nov 4, 2006
685
swansea
Ok cheers traumapat Ive got my Porsche brakes ready to fit now so next is getting all the bits needed for the bt conversion. So I can get the intake manifold and pipe work ready for the intercooler off a lcr?
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
decide which BT you want first. DPJ i think has an lcr intake and similar pipework, Jamiebennet may be another.
my intake is the stock lc one, ~TB on drivers side. pro alloy do a particular kit for the IHI turbo fitment. i imagine this is what i have.
try to get a parts list off your chosen tuner, that will give you an idea of what they need to get you the figures. see what they reccomend. jabbasport may be worth a call ... i think they have possibly done more conversions than anyone else and know what works
i`d whole heartedly reccomend IHI turbos if set up right, mines been on almost 3 years without issue. jabba did an amazing job on the car.
