Graeme's LCR - Now Sold *wave*
Jun 23, 2011
627
Inverurie
This weekend past , all major rust/bad points on the body were cleaned up , sprayed , polished etc over the 2 days , 1 or 2 more small bits to get touched in.
replaced the ABS pump however toke a chance on a 2nd hand unit and it also had the G201 sensor code , so will need to bite the bullet and get the modified one that fixes this problem and get it fitted this weekend coming.
top pipe is fully fixed and not slipping now , good clean and a better clip on it has solved it (touch wood)
So only a new ABS unit and the car will be running smooth and ready to sell!
joshy514
Fleet Air Arm by ability.
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
What head unit is that mate? I need one for my double din console but not a clue what to get. Thinking about a cheap one as they do all the stuff I want, bluetooth and reverse camera input. How do you find your liquid gauge?
Sent from my iPhone
Jun 23, 2011
627
Inverurie
ah right , yeh i mean most the time have no problems with it , only thing i bit iffy with it is the little button when pushing to the right haha
the gauge itself works fine for me
whats up with yours like?
joshy514
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
My button doesn't like going to the right either, but I've worked it out if I have the heaters on a little it works better, maybe the warmth I don't know lol. What's the plans with yours now then?
Sent from my iPhone
Jun 23, 2011
627
Inverurie
haha
thats it finished and up for sale now :)
I had no real crazy plans to take it further to be honest , thinking about the cost of bigger turbos and engine internals , LSD's etc didnt seem worthwhile for what i use it for
gaz700
51
did you get the issue with the power beeing down fixed? was it the maf afterall?
Jun 23, 2011
627
Inverurie
power seems to be fine right now:funk: , im guessing it was just due to the top pipe and maybe the brake pressure sensors causing an issue :think:, it was only down by 10bhp so wasnt much
think last time i replaced the MAF the power was down by a good 60+bhp
gave the MAF and filter a little clean as well so might have helped :shrug:
Jun 23, 2011
627
Inverurie
hi mate ,
car was looking great!!
may i ask... how did you get such a good result cleaning the seats? did you use a particular product or method?
cheers
Arite , cheers :)
I used a Vacumm Washing Thing , friends with a local garage so bored it from them
(one of these http://www.ebay.co.uk/itm/Numatic-C...eaning-Equipment-/270580815141#ht_1111wt_1161 )
works a treat , im sure using a similiar method would work , all it is is sprays the soap into the seat, then u rub it down then hover it out while scrubbing it
