This weekend past , all major rust/bad points on the body were cleaned up , sprayed , polished etc over the 2 days , 1 or 2 more small bits to get touched in.
replaced the ABS pump however toke a chance on a 2nd hand unit and it also had the G201 sensor code , so will need to bite the bullet and get the modified one that fixes this problem and get it fitted this weekend coming.
top pipe is fully fixed and not slipping now , good clean and a better clip on it has solved it (touch wood)
So only a new ABS unit and the car will be running smooth and ready to sell!
, im guessing it was just due to the top pipe and maybe the brake pressure sensors causing an issue
, it was only down by 10bhp so wasnt much
